How do I uninstall BLIcon?
  • How do I uninstall BLIcon?
    I was using the trial and the trial period ran out.
    I decided for the price, I do not need it.
    I'm trying to uninstall it because the status icons stopped tracking properly.
    I went to interfaces and clicked disable but that did not restore my original icons. So I stopped hs and removed the blicon.dll and restarted. That did not help either.
    How do I remove blicon from my system and restore it to before the trial?
    -Tim
    -Tim
    HSPro - 3.XXX - Dell mini W7 x32
    Way2 Call
    Elk M1 Gold
    UPB HAI switches
    HAI RC2000 Thermostat
    All Blades plug-in have an uninstall that can be found in the Homesee/bin directory. Just run the exe and it's gone. You will most likely have to reboot to get your original icons back.
    Marty
    XPpro SP3 /w HS Standard 2.5.0.80, HSTouch Server - 1.0.0.70, HSTouch Client 1.0.0.73 HSTouch Android - 1.0.0.2, HSTouch iPhone - 1.0.0.2
    Playing with HS3 a bit but it's just play at this point.
      Marty,
      I don't see a bin directory under homeseer. I have homeseer pro if that makes any difference.
      I did a search for bl*.exe under homeseer HSPRO directory and came up blank.
      -Tim
      Way2 Call
      Elk M1 Gold
      UPB HAI switches
        Oh my, HSPro could have a slightly different directory structure than the standard version. the "Bin" directory should be in the root of whatever your main HS directory is called.
        If it's not there you may have to wait for Blade to get back from vacation for a real answer. Even if you disable it and then reboot you should get your standard icons back, as far as I know.
        Marty
          Nope the BIN directory is in the HS root directory (ie: c:\programe files\homeseer2\bin) and the uninstall is there. Just checked on HS Pro.
          HomeSeer 3 V 3.0.0.318 with ALEXA (AKA Amazon Echo)
          BL Radar V2.0.217; BLRF V2.0.85.0; HS Touch V3.0.0.1034 X10 V3.0.0.42; PHLocation V3.0.0.38; Zwave V3.0.1.110; X10 V3.0.0.42
          BLBackup V2.0.39;ImperiHome3.0.0.20 All on Windows XP Pro
            I have programfiles\homeseer Pro\
            No bin directory at all. What is the name of the BL uninstall utility. Maybe I can search for it that way.
            -Tim
            Way2 Call
            Elk M1 Gold
            UPB HAI switches
              the filename is unins000.exe but all Blades un-install files are. It would be in a BLIcon directory. Just don't run the same filename from another directory or you'll be un-installing something other than what you want.
              Marty
                The file is simply called unis000.exe
                  C:\program files\HomeSeer Pro\BIN\BLIcon
                  Any icons that you had assigned in the plugin will remain until you activate the device, ie:
                  If its a light, select on, then off, and the default icon should return.
                  TrOjAn
                    If you dont have it you can manually uninstall the dll and the following folders:
                    \HomeSeer Pro\html\Images\BLIcon
                    \HomeSeer Pro\html\Images\Config\hspi_BLIcon.ini
                    \HomeSeer Pro\html\html\bin\blicon.dll
                    \HomeSeer Pro\hspi_BLIcon.dll
                    TrOjAn
                      TrOjAn
                      You will also have to uregister it with windows - have a read here http://board.homeseer.com/showthread.php?t=117892
                      Or you could try re-installing it and see if you get the uninstall prog.
                        One would assume that Homeseer is shut down, unable to delete files in use otherwise, so no need to unregister the files :P
                        TrOjAn
                          This is weird.
                          Why don't I have this BIN folder?
                          -Tim
                          Way2 Call
                          Elk M1 Gold
                          UPB HAI switches
                            Thanks for the file list to delete. I got through all of that but my blicon's were still there. Even after activating/deactivating.
                            I ended up deleting them and re-importing them from the jds stargate plugin. Was only a half dozen or so, not too bad. Could have been much worse.
                            Thanks for the help
                            -Tim
                            Way2 Call
                            Elk M1 Gold
                            UPB HAI switches
                              Just an after thought, I presume your BIN folder had not managed to become hidden somehow.
