Really need an uninstall
  • Really need an uninstall
    Hi Blade,
    How do I uninstall this and get my old icons back??
    I'm not sure about this plugin but many of the newer plugins can be removed using the add/remove programs or programs and features control panel applet. Otherwise you could just disable the plugin via the Setup > Interfaces tab.
    -Rupp
      In your homeseer 2/bin/blicon folder you should find an uninstaller.
      Marty
      XPpro SP3 /w HS Standard 2.5.0.80, HSTouch Server - 1.0.0.70, HSTouch Client 1.0.0.73 HSTouch Android - 1.0.0.2, HSTouch iPhone - 1.0.0.2
      Playing with HS3 a bit but it's just play at this point.
        no uninstaller in the /bin
          I did disable it under interfaces but icons has not changed back to original icons
            If you do not reset them then they will not change unless you have another plugin changing them.
            -Rupp
