I am using port 2525, which I am assuming that was the default when the plugin was loaded. I even tried adding a rule to the windows firewall for that port even though the windows firewall is shutoff. I see them in what looks like to be some sort of a pattern, :04, :24, & :44 minutes after every hour.
