No Devices showing in the HomeSeer Driver in Allonis
  • No Devices showing in the HomeSeer Driver in Allonis
    I have just installed BLML2HS (2.0.35.0) and BLML2HS_Allonis_4.0.8, both clients in the plugin show as being connected. Both columns are checked in the plugin (BLHS and mySvr). The BLHS sever variables are showing up in mYserver, but the devices are not being shown in the HomeSeer Driver. The server IP in the HomSseer driver and BLML2HS plugin are the same. The BLML2HS port is listening on 95 and the HomeSeer driver port is listening on 8787. Any help would be appreciated.
    Are you speaking about the homeseer device driver in Allonis? If so, the homeseer driver is now an Allonis plugin - go to device driver in Allonis, go to homeseer settings and make sure the IP and port settings are correct. If on the same machine use 127.0.0.1 as the IP - the default port is 8686
    Then click synchronize and you should have them all connected.
      Thanks for the response. I do have the Allonis Homeseer drive configured. I have included attachments showing the configuration:
      Allonis Driver:
      Blade's Plugin:
      Please let me know if I am missing something.
        If HS and Allonis are on the same machine, change both IPs to 127.0.0.1 -- that is localhost so it doesn't need to resolve the address...
          Maybe that is where i am getting confused,. They are on two different machines. I though both IPs (BLMS2HS and Allonis Homeseer Driver) had to be the IPs of the HS3 server.
            I must be missing something with the plugin. When I disabled the plugin and point the Allonis Homeseer driver to the HS3 server and port, it will synchronize. Can someone post a pic of the settings they are using with the plugin and Allonis driver?
            Thanks.
            Sent from my Pixel XL using Tapatalk
              Again, I have both on the same machine -- by the way, I recommend this, much easier to manage.
              I think Blade is on vacation for a few weeks so I don't think you will get a response - just trying to help because his plugins are so awesome!
                The other issue with multiple machines is firewalls - you need to make sure all those ports are open.
                I suggest installing Allonis on your homeseer machine as a demo version and configure and test. Once that works then try communicating with the second machine.
                  Thanks, I appreciate the help. I am going to try your recommendation and install Allonis on the same machine as Homeseer. I will post the results.
                  Thanks.
