Homeseer showing disconnected yet working fine
  • #16
    That could happen if the device changed in HomeSeer while mlserver was shutdown
    Can you put in a help desk ticket for this so I can track it
    Will need to give this some thought
    Cheers,
    Bob
    • #17
      I am reasonably sure that the devices in question did not change status in the time that I waa rebooting the server, especially as homeseer was also being rebooted. So I think something else is happening here. I do know that it didn't always do this, that this is something that started happening recently. Although I can't be absolutely sure I think it was at the time that the homeseer driver was released from Allonis.
      • #18
        Do you run both BLML2HS and the Homeseer driver?
        I have not seen my devices get out of sync here but perhaps I need to look more closely
        Cheers,
        Bob
        • #19
          I do run both. I use the homeseer driver to control lights etc. that are in homeseer. I use your plugin to do most of the other stuff - manage variables, etc.
          • #20
            OK - can u log a help desk ticket on my web site so I can track this
            I will come up with a way to refresh devices on a restart
            Cheers,
            Bob
            • #21
              Ticket logged yesterday. Thanks.
              • #22
                Ah I missed that - thanks
                Cheers,
                Bob
                • #23
                  Hi, did you every do anything on this? I have noticed that if MyServer crashes, or if is forced to restart through a restart of the machine (windows update for example), that it does not save the variable states correctly and consistently gets out of sync with a handful of variables. Weirdly it is the same variables every time. If I restart MyServer gracefully through the interface it is not a problem.
                  • #24
                    I could add some code so on a MyServer connect to the HS plugin, it could do a device refresh
                    I may make that an option in the plugin
                    Cheers,
                    Bob
                    • #25
                      Try out 2.0.37 in the beta section of the updater
                      Cheers,
                      Bob
                      • #26
                        Great. I installed it and forced a system restart and all variables were correct. I will play around with it a little more. I don't see an option to turn the refresh on so I am assuming it is doing it automatically? Thanks.
                        • #27
                          There is a new option on the options web page
                          You do need to turn it on
                          Cheers,
                          Bob
                          • #28
                            Hi - this works great now. Everything is in sync after an abnormal shutdown.
                            As an aside - any idea what is going on with Allonis? There have been essentially no updates this year and the forum is very quiet.
                            • #29
                              There are updates but only if you have a paid subscription
                              I have chatted with Dave a few times so I know he has been working on things
                              Cheers,
                              Bob
                              • #30
                                I do have the subscription but I have seen nothing. Not one plugin has been update in about 12 months
