I see thanks.
I have a Insteon Device "Theater Counter Area" with the Homeseer code of "]1" set in the BLML2NS Plugin Devices list assigned to the ML Code of "t1".
BLML2HS|HS-ExecX10~]1~Off works
BLML2HS|HS-ExecX10~t1~Off does not.
Am I misunderstanding that?
It does show up MainLobby Class blml2hs_t1 with multiple variables.
I'm probably misusing it in the above command and should use "]1"?
