How to dim device
  • How to dim device
    Anyone have an example ho to Dim a homeseer device from Mainlobby ?
    I have tried the following and the dimmer bar in HS moves but the device will not Dim
    BLML2HS|HS-ExecX10~06.C7.FE:1~Dim~20
    On and off work
    BLML2HS|HS-ExecX10~06.C7.FE:1~On
    BLML2HS|HS-ExecX10~06.C7.FE:1~Off
    Jeeperboy
    How to dim device
    If you are using hs3 that command no longer works I believe. Hopefully someone else knows the right way of doing it.
    Sent from my iPad using Tapatalk HD
      If you are using HS3 try this:
      MLServeCmd.BLML2HS|HS-ControlDevice~06.C7.FE:1~Dim~20
      The best way to see the commands is to use the command builder in MLServer 4
      Cheers,
      Bob
        Blade
        didn't work I think it might be a HS3 bug at this point.
          Try 2.0.8 in the HS3 updater
          If you still have problems then do the following
          Turn on debug logging in the HS plugin and run the command in MLServer
          Then turn off debug logging and attach the BLML2HS-Detailed.log file zipped here and I will have a look
          Cheers,
          Bob
            Blade,
            Thanks that worked. All fixed.
            Jimd
              Syntax for controlling a HS Device?
              Hello Blade,
              I'm trying to control a HS/2 device *1 which I've substituted the asterisk with the letters SP in your HS/2 plugin. The ML device BLML2HS_SP1 displays the correct status, however, when I try to control the device with the following ML command it doesn't seem to work:
              BLML2HS|HS~ControlDevice~SP1~On or BLML2HS|HS~ControlDevice~SP1~Off
              Am I doing something wrong?
              Todd
              -Todd
              ____________________________________________________________ ________________
              HS2Pro: 2.5.0.81 :: HS3Pro (beta) || Plugins:| SmartHome PowerLinc USB, Global Cache, BLBackup, DooCPU Monitor, DooMotion, BLOutlook, BLIcon, BLOutgoingCalls, OutgoingCalls, ROC-Rnd, HSTouch iPhone, UPS Monitor, DooMenuBar, BLSpeech, HSTouch Server, WAF AB8SS, mcsTemperature, VWS, BLChart, RFXCOM, ISY Insteon, iAutomate RFID, iTunes, NetCAM, DSC Security, Nest
                In HS2, HS-ControlDevice does not exist. You need to use the HS-ExecX10 calls
                Try
                BLML2HS|HS-ExecX10~SP1~On
                Cheers,
                Bob
