HS3 / ML4 --> always disconnected...
  • HS3 / ML4 --> always disconnected...
    Just downloaded the BLML2HS plugin (have not registered yet).
    Running the following versions:
    HS3 Pro 3.0.0.163
    BLML2HS 2.0.16.0
    ML Server 4.0.5611.15771
    BLML2HS For MLServer 4.0.4.0
    Running HS3 on 192.168.1.21 and ML4 on 192.168.1.22, both are Win 7 Prof 32bit machines with no firewall or antivirus.
    I have set up in HS like this:
    Server IP Address 192.168.1.21
    Server port number 95
    and on ML like this:
    Server 192.168.1.21
    Port 95
    Both ends always read disconnected...
    I have enabled debugging on the ML side and this is what the log reads:
    15/05/15 17:41:39 : v4.0.4.0 - **************** Debug Logging ENABLED at 15/05/15 17:41:39 ****************
    15/05/15 17:41:41 : v4.0.4.0 - Connect_To_Server() started
    15/05/15 17:41:41 : v4.0.4.0 - Connect_To_Server(): theServer --> 192.168.1.21
    15/05/15 17:41:41 : v4.0.4.0 - Connect_To_Server(): thePort --> 95
    15/05/15 17:41:41 : v4.0.4.0 - Connect_To_Server(): userStarted --> True
    15/05/15 17:42:02 : v4.0.4.0 - Connect_To_Server() finished
    No error anywhere. Also checked the HS log and no error there either...
    I am at a loss!
    Cheers
    Sandro
    Update - please ignore previous post - all that was needed was a reboot of the HS3 machine. All connected OK now.
