Plugin status variable
    I was looking for a variable in MLServer that indicates the state of the BLML2HS plugin (i.e. if it is connected to HS or not) but couldn't find it.
    Alternatively, can I get the status of the interface in HS? Then I can set a virtual device with the value and send it over.
    I would like to display the state of the interface on my touchscreens using ML. I use this to make sure the information I am seeing is up to date and not static (that happens if the plugin disconnects)
    Any suggestion?
    There should be a variable for this. I will have to look and see the exact name of it as it has been a while since I looked at it
    Cheers,
    Bob
      You should be able to use the following variable
      blml2hs_connection_string (Connected/Disconnected)
      blml2hs_connection_status (On/Off)
      Cheers,
      Bob
        Thanks a lot Bob, found it. Would be great if it made it into a revision of the help document at some stage. Also, I noticed while using the help file yesterday that some sections reference ML2HS as opposed to BLML2HS in the examples. No big deal, just wanted to let you know.
        Cheers
          Yea that was the old name of the MLServer plugin. I will go through and update the references
          Cheers,
          Bob
