Disconnected...
  • Disconnected...
    I have the latest Allonis installed @ 10.0.0.80 and the BLMS plugin is running.
    I have configured the plugin in Allonis to the HS3 IP 10.0.0.70
    The latest plugin is installed and running in HS3 and set to the Allonis server IP 10.0.0.80
    Both HS3 plugin and the Allonis plugin show disconnected.
    I have rebooted both servers, no firewall is installed or enabled.
    I have clicked on 'connect' in the Allonis plugin...nothing.
    What next? This is a new install, not a migration from ML4.
    Logging in HS3 with plugin debug logging on, only shows 'turning on debug logging!'
    I just loaded myServer and HS3 on a new machine and they are running OK
    The ML2HS plugin in myServer should have the ip address of the HS3 machine and a port
    In the HS3 plugin you need to setup the ip and port to match in the options page
    Do not forget to start the server on the status page
    Cheers,
    Bob
      OK, I changed the plugin in HS3 to point to itself (same IP as the HS3 instance is running on), and now everything is good.
      Thank you!
        I was going to to say that both IP addresses must be the HS3 server
        Cheers,
        Bob
