Originally posted by avargaskun
View Post
HSBuddy feature requests
This is a sticky topic.
Very good app, with lots of features, Thanks :-)
For an improvement / new feature My use case is I let my spare room out, and have family and friends who i would like to give them access for various reasons.
A method of providing a link / file to a person so that the app is maybe installed but then pre-configured for that user or group of users?
Configuring each individually is a little cumbersome and requires some dedicated time to verify settings etc.
tweaking settings from HS would be a nice to have also ;-)
Would it be possible when sending an HSBuddy notification to have the option of attaching snapshots from 2 separate cameras instead of just one? I have a kind of oddball situation where I have cameras that cover the area on either side of a gate. I get a notification when the gate is opened but as it stands now I can only get a snap from one camera or the other (so essentially only of whoever's coming in and not going out (or vice versa)... if I could attach two snapshots then I'd be golden. I can also see that this might be useful if you have two cameras covering a yard and you want to send a motion notification that has the view from both.
Originally posted by mcisar View PostWould it be possible when sending an HSBuddy notification to have the option of attaching snapshots from 2 separate cameras instead of just one? I have a kind of oddball situation where I have cameras that cover the area on either side of a gate. I get a notification when the gate is opened but as it stands now I can only get a snap from one camera or the other (so essentially only of whoever's coming in and not going out (or vice versa)... if I could attach two snapshots then I'd be golden. I can also see that this might be useful if you have two cameras covering a yard and you want to send a motion notification that has the view from both.
Hello, I would like to access the HsBuddy Server through a VPN clearly using an internal IP address of my local network. However, it seems to me that if the App. does not detect the WiFi connection the local connection is not taken into account thus ignoring the VPN. Is it possible to work around this problem? thank you
For (iOS) Push Notifications, I would like the ability to select a "None" sound option for the Notification Sound.
Right now, you can select from several different Notification sounds, but there's no option for "NO SOUND".
I typically keep nearly ALL Notifications set in iOS as 'Sound Off'. This suppresses any Push notification from NOT making a sound. I would like to leave this iOS setting as Sound ON for HSBuddy Notifications, but I do not want all Notifications to make a sound, only a few 'emergency' type notifications would be able to make a sound. Basically, I would like to curate/choose which HSBuddy notifications initiate a sound on my phone when I create the Event Action for Send Push Notification.
If an extremely quiet (i.e. silent) sound file could be invoked so that there is a "NO SOUND" option in the dropdown, that would be great!
Could the geo features add for each geoposition:
- driving distance (using google or some other service)
- incomming / leaving
- and the craziest one: refresh update to be set by server on app. Ie. from the HS server I can ask the app to live stream position to get very high freq. on updates and visa versa. This way I could ask the app only to update every 10 min. if the phone is more than 10 min. away. And to livestream posiions if app was less than 2 min. (or 400 meters) away.
Best,
Jakob Sand, I automate everything!
Would it be possible for the plug-in to create each GeoFence as a device in Homeseer? What I am after here is leveraging EasyTrigger to make announcements for each location using one event instead of a separate event for each location and device. This would greatly cut down on the overhead of managing events, since I would just have one Easytrigger group that I would add all of the locations into, and then use the ET global variables to speak the location out.
Right now I have about 60 events total for this purpose. This would eliminate all but one or two. I have done this very successfully with things like batteries...anything that can be grouped in EasyTrigger is possible.
Thanks!
Originally posted by Steveo369 View PostFor (iOS) Push Notifications, I would like the ability to select a "None" sound option for the Notification Sound.
Originally posted by bebaldin View PostWould it be possible for the plug-in to create each GeoFence as a device in Homeseer?
Originally posted by avargaskun View Post
Thanks for the suggestion! There's been multiple requests to integrate geofencing information as part of HS devices. I've added a backlog item to keep track of this: https://trello.com/c/Uofz5Txt
