HSBuddy feature requests
This is a sticky topic.
Are homescreen widgets a planned feature? To control devices from the home screen on Android?
Originally posted by gelessor View PostThis is getting better and better!
really appreciate your efforts with this. Just sent some extra coffee money.
thanks againOriginally posted by langenet View PostI couldn't agree more. I just sent you some coffee money... Have some Bailey's with it!
Thank you for the support. And thank you for using the app and contributing ideas for new features
Originally posted by gelessor View PostAny chance you could add a function to a button press that would change to a different named dashboard?
I'll consider this feature, compound actions on a widget, for a future change. Thank you for the suggestion!
thanks again
Any chance you could add a function to a button press that would change to a different named dashboard??
I have a dashboard to run events as part of my home theater setup.
the dashboards are Home Theater, Cable TV, Kodi, PLEX, DVD, Lighting, etc.
It would be great if when I pressed the “Watch TV” button on the “Home Theater” dashboard it would not only run the associated event, but also switch to the “Cable TV” dashboard. Or when I pressed the DVD button it would automatically switch the the “DVD” dashboard that has the DVD player controls.
is something like this possible?
Originally posted by avargaskun View PostHey folks,
Starting a thread to capture your ideas of new features that could be built into HSBuddy (either the app or the server plug-in). I know you have previously sent me some via the app built-in bug report tool, or through private messages in the board. I'm hoping that this thread will be a more permanent place to keep track of those ideas.
To start, let me seed the list with the ones in the top of my backlog:- User-defined dashboards of devices
- Add support to connect to multiple servers
- Controlling timers and counters from their device details page
- Showing device history as a graph
- Implement user validation, require special user rights to access certain plug-in functionality
That isn't possible with HSBuddy yet. For the time being, there's a possible workaround using the EasyTrigger plugin from spud - this can be accomplished using a virtual device, a device group and an event. For example, an event to add the kwH measurement from multiple devices would look something like this:
Then in HSBuddy a widget for the virtual device can be addd to the dashboard and it will handle value updates like other devices. Fwiw, the EasyTrigger plugin supports much more than just the scenario described above, I use it extensibly on my own HS server.
Would it be possible to add this functionality to HS Buddy in the future? I use a lot of totals in ImperiHome.
Originally posted by ServiceXp View Post
Present a Total (Sum) Value
Originally posted by ServiceXp View PostAre we able to add the values from 2 controls into one widget yet?
A WAF thingy >feedback: My wife mentioned ( and I noticed as well) that when on the dashboard a button is pressed (I only uses icons, which toggles the switch) there is no confirmation/feedback. The confirmation comes from homeseer when the relays actually toggles, which takes a moment.
What happens is that for example the garage needs to open , the button is pressed , but since it takes a moment for the zwave relais to actually toggle and there is no immediate feedback, she presses it again, where the garage door now only partially opens.
Is it possible in the app to have a kind of feedback, maybe a circle/bloom or vibrate when a button is toggled.
Thanks, Cor
