After upgrading to HS4 I can longer get it to login to hsbuddy server
    #16
    A ticket is advised, if you were working before the upgrade there is nothing blocking communication from your side. Suspect there is a registry issues on the HomeSeer side. .. This assumes nothing is display on http://find.homeseer.com/findhomeseer/
    - CoyoteRay
      #17
      Has anyone here gotten this to work? I recently upgraded to HS4 and cannot log in remotely with HSBuddy. I can log in remotely with Homeseer Mobile and myHS, just not HSBuddy. I can access with HSBuddy locally, but I really miss the geofencing. I submitted a ticket but they asked if it might be a firewall issue since myHS works. I shut it down, but still no connection. The error says the request timed out. Details are "Address (blank), status 1. Everything worked fine with HS3. Any ideas?
        #18
        Originally posted by Kevb View Post
        Has anyone here gotten this to work? I recently upgraded to HS4 and cannot log in remotely with HSBuddy. I can log in remotely with Homeseer Mobile and myHS, just not HSBuddy. I can access with HSBuddy locally, but I really miss the geofencing. I submitted a ticket but they asked if it might be a firewall issue since myHS works. Everything worked fine with HS3. Any ideas?
        Did you try shutting down your firewall and testing?
        -Rupp
          #19
          Yes, still didn't connect. sorry, I'll update my post...
            #20
            Have any of you guys contacted the plugin author via PM's for assistance. This can't be that hard to fix.
            -Rupp
              #21
              HSBuddy started working remotely for me this morning. Not sure why, I didn't change anything. Glad it's working!
                #22
                HI everyone,
                I had the same problem. I just changed the password on myhs and it worked for me. Obviously you will need to change the PW on the homeseer server too.
                I did try changing it all back to the previous PW I had before with HS3 but it wouldn't work again. All very strange but I'm happy its all working now.
