I am just testing the plugin and app and have run into an issue that I do not understand:
I have two separate HS(3) installations that I can access through myHS premium.
What I can not figure out is how to select which of these two to connect to in the HSBuddy app. Only the default "main" myHS username and login for my account seems to be working in HSBuddy, none of the "secondary" users.
The problem with this is that as long as I log in with my default username I always get connected to the default HS3 system, the other system is not accessible.
I have previously set up several secondary users that have only access to one or the other instance of HS. If I try to use any of these usersname/password combinations in HSBuddy, they do not work, just get error messages indicating that I do not have access.
However, sending JSON commands to these same usernames manually or through other apps works fine, so it is not a problem on the myHS side it seems.
Is it me who is doing something wrong or is HSBuddy not supporting more than one HS installation through a single myHS account?
