Camera resolution bug anyone?
    I have a couple of cameras configured using UltraNetCam3. I added them to the dashboard this past summer and image clarity was perfect using the default 3 second refresh - small and full screen. After updating the Android App, and looking at the dashboard, my 2 cameras show great in small size. However, if I click on the image to expand, it opens up full and is clear for a second then the resolution degrades. So I go into the camera's themselves (on sidebar) and change the refresh to 5 seconds for example and all is fine. Close the app and re-open, even with a refresh set to 5, resolution goes bad as before. Going into cameras directly after closing and opening HSBuddy, the cameras show perfect resolution. So it seems to be linked to the dashboard somehow. This is repeatable every time. I still have Emperihome and it works fine as well...
    Anyone else seeing this?
    Robert
    Hi. Thanks for the detailed explanation. Can you try the following? Go to the plug in configuration page in HS and under Cameras disable the option to Resize images. Does it help?
    The downside of turning this option off is that more data will be transferred for each snapshot. But assuming you're using a local connection that shouldn't be a problem.
      That works but it's not the best solution as my primary use is remotely. I'd rather not use more data. This wasn't the behaviour of the previous release. Any other options?
      Robert
        I tried this yesterday but could not reproduce the same behavior.
        Can you send a feedback report from the app? That may help figure out what's going on. First go to the Options->Feedback section and enable 'debug logs'. Then close/open the app and try the scenario from the beginning. Make sure to stay in each screen for a few seconds to get a couple image refresh operations. In the bug report please add the name or the camera.
