Hi
when I associate the Widget Type: Label to a Device I have the possibility in the Widget Text to insert the Last Change.
This gives me the information about the last state change of the device. But on a battery-powered sensor, where I need to check the state of charge of the battery, I would need to know the date and time of the last communication with HS4 of this information even without the battery charge change (therefore without no change of status) which in my system is set once a day.
Is it possible to add this information to the widget text?
Thank you
Thank you
