After succesfuly migrated from HS3 to HS4 I'm trying to connect to MyHS via HSBuddy but with no luck.
These are my already executed attempts:
- Made a local user with admin rights and same name and password as MyHS (and re-created it a few times)
- Deleted MyHS account and made a new fresh one
- Changed the alternate authentication under General setting in the app.
- No problem approaching MyHS via browser on my mobile phone using providers network (not WiFi)
- Option checked in HS4 to acces MyHS
- Using the wifi setting in HSBuddy works fine
- Using the DIRECT option with my own home connection IP settings also works fine.
- I have only one system so this is the primary in MyHS
The error in the test result received from Homeseer as from HSBuddy Plug-in are the same
Someone got a clue to solve this?
Wil.
Wil.
