Beta: Smart Tag (NFC) support
Just re discovered this app and am really excited to try out the NFC tags. I have been watching these for a while and they look like they could be very cool little automation engines when used correctly. Plus it is just fun to nerd out over something new!
Originally posted by avargaskun View Post
That's unexpected. In my case the event runs immediately. The app registers the tap on the tag with the server at the same time it checks for local shortcuts so the delay is most likely on the server. In the log you should see a line similar to "Client xxx scanned smart tag yyy". Is the delay between that line and the event actually running?
However when I import the tags to my wife's phone and tested it none of the tag responded it just opened the app. Both are set on the server events
Originally posted by wkrasner View PostI am interested as well
Originally posted by dannieboiz View PostSo actually, something did happen when using events but it took from the time before I first posted the previous respond to about a minute ago before HS triggered. That's about 10 m minutes. Using the phone shortcut it took maybe 5 seconds but it had to launch the app
Didn't know about the ability to set it up on the server. I remove the shortcuts on the phone set up an event as shown but nothing happens.
Originally posted by dannieboiz View Posttook a second to work but it worked perfectly! I can unlock my door. BTW can both mywife and I use the same smart tag for the same trigger?
Yes, the same tag can be used by multiple phones. If you setup the automation in the server (using the HSBuddy Smart Tag event trigger) you don't need to import the tag in additional phones. If you want to setup the automation as a shortcut in the app, you will need to import the tag and create the shortcut in each phone. I prefer setting the automation in the server. To import a tag on additional phones use the Read Tag option first and after scanning the tag tap on the Import Tag option.
strange I didn't get notified that it needed an update I was on 3.18.721.0. I had to go to add then do a reinstall when I noticed the version difference. it did save now. time to go play
BTW this feature is available now in the latest release of the app. You no longer need to be in the beta to get access. Thank you to those who tried it early and gave feedback!
Originally posted by dannieboiz View PostFor whatever reason I'm getting a "failed to export smart tag to server" I'm on my local network and HSBuddy is accessible.
I believe our phones (android) needs to be unlocked to work? if we can somehow bypass this it would be even better. tags should be here in a couple days.
Same thing when you use Google Pay on a phone, one has to unlock before the virtual credit payment will work.
sign me up. I ordered some NFC tags specific to test this.
One at the garage and one at the front door tab to unlock/open
not to hard to ask right?
