Got this when trying to send picture via event. Event is below. Not getting anything on HSBuddy app in phone. Help please ??
Push fails from event
Originally posted by avargaskun View PostMake sure you are running the latest version of the plugin. Should be 3.28
This seemed to update ok according to the log, however maybe not since I now have some errors in the log and on the PI page after the update.
Thanks for the note - I think other's have reported the same issue with the updater not picking up the latest version. I'll keep an eye on this when the next version comes out.
Regarding the second error, I think someone else mentioned they had seen the same. If I remember correctly, it seemed to be related to some conflict between plugins. Would you be able to troubleshoot by disabling all plugins and enabling only HSBuddy? Does the error persist in that case?
Still have the message shown in the HSBuddy PI tile and don't have any HSBuddy plugin access from the menu.
UPDATE...
I started to see same issue on other plugins on my system. Then a search of the forums shows this happening to many on various plugins.
I rebooted HS4 server which didn't seem to help.
Went to HS4 server and saw on event log a .NET error just before the plugin crash.
Stopped HS4. Ran CCleaner find and remove issues in registry on HS4 server. Rebooted server. HS4 started normally. All my plugins started normally and show as expected with no unusual errors.
So I don't know exactly what was happening but just happy with the current status!
