can't set up geolocation
    server plugin 3.28.1222.5
    android 11 app 1.0.72
    am able to connect to server (test & save in app works, client listed as registered client in HS plugin) but when try to enable geolocation get this error:
    Test results
    Home
    {"errno":"ENOTFOUND","code":"ENOTFOUND","syscall":"getaddrinfo","hostname":"NAMEOFMYHSSERVER"}
    have two geofence locations configured in the plugin
    app does have location permissions on phone
    didn't find anything when searching for this error. what should i check?
    thanks
    Hello!
    In order to use Geolocation it is necessary to configure the connection to use either MyHS or a public internet address where your server can be reached (for example, if you have a custom DNS)
    From the bug report and the image above, it looks like your server connection is configured with the address "pitroller", which is not an address reachable via the Internet. You could try setting up a MyHS connection and also enable a "local" connection to speed up commands while connected via your home WiFi.
