Running PI v3.28.1222.5 on HS3 Pro v. 3.0.0.548 on Win10 Workstation. Dual 8 core Xeons and 64GB RAM, so probably not a horsepower or memory issue. CPU rarely goes above 25% and never above 30%. Memory utilization is 12-15% max
PI get stuck at starting up. No errors in log, just an entry that it's initializing.
After I disable it, I have to go into Task Manager and manually kill the process. When I do that, I get this log entry in HS.
Initializing plug-in(2): HSBuddy Instance::Object reference not set to an instance of an object.STACK: at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces()
I also get this entry in the windows log after
Application: HSPI_HSBuddy.exe Framework Version: v4.0.30319 Description: The process was terminated due to an unhandled exception. Exception Info: System.NullReferenceException at HSPI_HSBuddy.History.DeviceHistory.Dispose() at Autofac.Core.Disposer.Dispose(Boolean) at Autofac.Util.Disposable.Dispose() at Autofac.Core.Lifetime.LifetimeScope.Dispose(Boolean) at Autofac.Util.Disposable.Dispose() at HSPI_HSBuddy.Program.Main(System.String[])
I've tried changing the PI load order (from middle, to first, to last)... no change...and no PIs load after it attempts to start, regardless of order. And while it's trying to load, it gums up other stuff. (Ultralog syslogging starts to overflow), system becomes less responsive/sluggish.
Also tried wiping out config/log/db files for the PI. new files created, same old experience.
Love the PI, just recently started futzing with the NFC tag functionality. Super cool.
Any ideas?
Any ideas?
