I've got a device on a Dashboard that shows state and time of last update and has history displayed on 1-Tap. Corresponding device on HS4 is set to update date and time when written to even if the device state does not actually change. This shows up properly in HS4 (date and time of last update shows even when device state does not change) but no update shows in HSBuddy (last update date and time shows as when the state changed, not when the device was updated in HS4). This is not a transient state difference in that full close of the app and restart does not resolve. Only resolution is when the state itself is changed in HS4. This means that the date and time of last change does not get updated in HSBuddy and therefore the devices record in HSBuddy shows correct state of Device in HS4 but the date and time of last change shown in HSBuddy is not correct. I'm using latest version of both plug in (3.28.1222.5) and Android App (1.0.77). Is this a known defect or do you need more info to fully describe?
Thanks for the fantastic interface.
