I am experiencing a problem where push notifications are sent to a Fire Tablet which is confirmed in Options > Notifications, and Server > [Notifications tab] but the pop-up never appears. I can reproduce this indefinitely. Any ideas, or is this a bug?
Push Notifications Do Not Appear on Fire Tablet
Hello! This is an actual issue with HSBuddy running on Fire Tablet since they use a different notification channel than Android devices. I don't know if someone has figured out a workaround - I have added a proper fix to the backlog.
Btw, out of curiosity, did you install the app from the Amazon store or did you side-load the Play store?
Originally, I had side-loaded the app using the Play store which resulted in version 1.0.77 being installed. In case there was a difference with the app on Amazon App store, I removed the original installation and then reinstalled using the Amazon App store which resulted in version 1.0.75 being installed. The behavior between the two was the same.
The notification does not pop-up on the screen or in the pull-down window notifications area. I have confirmed notifications are enabled for applications, and confirmed HSBuddy is receiving the notifications since they appear in Options > Notifications, and Server > [Notifications tab]. I am just unsure how to get the notifications to appear on the screen. FYI, my Samsung Galaxy S21 does display the notifications on the screen when HSBuddy is the active application.
me229 I've just submitted version 1.0.77 to the Amazon Store which enables notifications for Fire tablets. It should become available for download within a week. Let me know after you install it if things are working as expected. I did limited testing on my end and notifications seemed to behave same as in other Android devices.
Originally posted by me229 View PostI just checked for the updated version and do not see that Amazon has published the new version yet.
