Is it possible to download a dashboard to a different logged in user? I use different logins for each client which allows me to control permissions. I would like to use the same dashboards, however, without completely rewriting them for each login, as this is very time consuming.
Downloading Dashboards to a different login?
Hi Ltek - currently working on better server-side dashboard management. Thank you for the suggestion - manually pushing dashboards to clients is in the list of todos.
Hopefully some of the following could be used as a workaround:
- From the Dashboards section, tap on the right-side menu, then "Manage Dashboards". Download the dashboards you're interested in and then enable 'auto-sync changes'. This will bring down to the device any changes that happened on the server every time the dashboard is loaded.
- From the Options section, go to Home Screen, tap on Dashboards and select the dashboard you want to always launch when the app is first opened.
