Windows Style Live-Tile UI for HomeSeer
This is a sticky topic.
  • #76
    Originally posted by claude View Post
    It's confusing at times when we talk about status with the ACSII interface.
    When you say "works for me w/ status. I'm on .152", I assume you mean sending a status request and getting a response back.
    With 153, HS3 will send unsolicited status changes to any client that has a TCP connection on port 11000 (without the client asking, just listening). I assume you are not getting these unsolicited status changes.
    Could you confirm?
    Hi Claude...
    I am not asking for any status. I'm getting all unsolicited updates. I'm doing just as you say above and opening a TCP connection on port 11000. Once that happens, I start receiving all status updates. I don't post any updates over the ACSCII interface and I don't ask for any updates.
    • #77
      Correct. I misunderstood the question
      Could you confirm?
      Correct. I now understand the difference.
      Don
      • #78
        BTW, I ordered one of these for to use for my main wall-mounted touchscreen and to run my UI: http://www.groupon.com/deals/gg-hp-s...id-business-pc
        $239 for a 21" android tablet?? Once I get it and have a chance to play with it for a few days, I may order another.
        • #79
          Looks like a great deal! I may be tempted myself so I'll look forward to your review.
          • #80
            Hi Claude...
            Hi Wposner,
            My comment was more for Donstephens. I was under the impression he was receiving unsolicited status changes via you app but on 152.
            • #81
              Pity they wont ship to UK....Here we can't get anything close to such a product/price !
              • #82
                So, is the purpose of the proxy to detect unsolicited device changes?
                Don
                • #83
                  Correct. The proxy brokers the changes from homeseer and causes the UI to automatically update without having to do a manual refresh.
                  • #84
                    I will be watching this thread, l really like this idea.
                    Hector
                    Win.2003 OS, HS3
                    MyTrigger,ACRF2,W800,Zwave
                    AP800,Honeywell Stat
                    • #85
                      Dont' just watch. Download the UI from the first post in this thread and give it a try!
                      • #86
                        So it's already functional? I must have miss read, I thougth it was still under development . So is this for folks that are using HSTouch? Will this work for iPad users?
                        Hector
                        Win.2003 OS, HS3
                        • #87
                          Hstouch is not required. If you've got a web browser you can use this UI. iPad, android tablet, laptop--doesn't matter. It will work.
                          • #88
                            Originally posted by Furious View Post
                            The horstmann thermostat I have comprises of a root device, heat setpoint child, current temperature child and battery level child.
                            This controls a thermostat device which itself comprises a root node, hot water child (on/off), boiler child (on/off), and a control mode child (heat)
                            Appreciate the work you're doing
                            Can you put the following in a browser and send me the result?
                            http://<your homeseer ip>/JSON?request=getstatus&ref=<id of your root thermostat device>
                            Then for each number in "associated_devices" execute the same URL from above using those numbers for the ref value. So instead of your root ID, use each of the "associated_devices" IDs.
                            My Nests have a root ID and 7 associated devices. Your thermostat has a root ID and only 3 or 4 associated devices (from what I gather). I only need certain info to build a useful thermostat control, but I need to see the JSON that is being returned for your devices to make sure they don't deviate from what I've got with my Nests.
                            I need you to send me whatever is in your browser for each ID.
                            • #89
                              • #90
                                Device Info for CT100 Thermostat
                                Here is the output for one of my CT100 thermostats. It has 9 child devices in my application but could have more with multi-stage heating/cooling systems. This is determined in the setup of the thermostat when installed and prior to scanning by the Ztroller.
                                Root:
                                {"Name":"HomeSeer Devices","Version":"1.0","Devices":[{"ref":301,"name":"Downstairs Thermostat","location":"Kennesaw","location2":"Kennesaw Thermostats","value":255,"status":"No Status","device_type_string":"Z-Wave Thermostat Root Device","last_change":"\/Date(1407535948827)\/","relationship":2,"hide_from_view":false,"associated_devices":[349,350,351,352,353,354,365,366,402],"device_type":{"Device_API":16,"Device_API_Description":"Thermostat API","Device_Type":99,"Device_Type_Description":"Thermostat Root Device","Device_SubType":0,"Device_SubType_Description":""},"device_image":""}]}
                                Local Temperature
                                {"Name":"HomeSeer Devices","Version":"1.0","Devices":[{"ref":349,"name":"Downstairs Ambient Temperature","location":"Kennesaw","location2":"Kennesaw Thermostats","value":67.5,"status":"67.5 F","device_type_string":"Z-Wave Temperature","last_change":"\/Date(1425992407948)\/","relationship":4,"hide_from_view":false,"associated_devices":[301],"device_type":{"Device_API":16,"Device_API_Description":"Thermostat API","Device_Type":2,"Device_Type_Description":"Thermostat Temperature","Device_SubType":1,"Device_SubType_Description":"Temperature"},"device_image":""}]}
                                Fan Mode:
                                {"Name":"HomeSeer Devices","Version":"1.0","Devices":[{"ref":350,"name":"Downstairs Fan Mode","location":"Kennesaw","location2":"Kennesaw Thermostats","value":0,"status":"Auto","device_type_string":"Z-Wave Fan Mode","last_change":"\/Date(1408769084515)\/","relationship":4,"hide_from_view":false,"associated_devices":[301],"device_type":{"Device_API":16,"Device_API_Description":"Thermostat API","Device_Type":4,"Device_Type_Description":"Thermostat Fan Mode","Device_SubType":0,"Device_SubType_Description":"Fan Mode"},"device_image":""}]}
                                System Mode:
                                {"Name":"HomeSeer Devices","Version":"1.0","Devices":[{"ref":351,"name":"Downstairs Heat/Cool Mode","location":"Kennesaw","location2":"Kennesaw Thermostats","value":1,"status":"Heat","device_type_string":"Z-Wave Mode","last_change":"\/Date(1425904200537)\/","relationship":4,"hide_from_view":false,"associated_devices":[301],"device_type":{"Device_API":16,"Device_API_Description":"Thermostat API","Device_Type":3,"Device_Type_Description":"Thermostat Mode Setting","Device_SubType":0,"Device_SubType_Description":"Mode"},"device_image":""}]}
                                Operating State:
                                {"Name":"HomeSeer Devices","Version":"1.0","Devices":[{"ref":352,"name":"Downstairs Operating State","location":"Kennesaw","location2":"Kennesaw Thermostats","value":0,"status":"Idle","device_type_string":"Z-Wave Operating State","last_change":"\/Date(1425983822234)\/","relationship":4,"hide_from_view":false,"associated_devices":[301],"device_type":{"Device_API":16,"Device_API_Description":"Thermostat API","Device_Type":1,"Device_Type_Description":"Thermostat Operating State","Device_SubType":0,"Device_SubType_Description":"Operating State"},"device_image":""}]}
                                Heating Temp Setpoint:
                                {"Name":"HomeSeer Devices","Version":"1.0","Devices":[{"ref":353,"name":"Downstairs Heating Setpoint","location":"Kennesaw","location2":"Kennesaw Thermostats","value":68,"status":"68 F","device_type_string":"Z-Wave Heating 1 Setpoint","last_change":"\/Date(1425978000344)\/","relationship":4,"hide_from_view":false,"associated_devices":[301],"device_type":{"Device_API":16,"Device_API_Description":"Thermostat API","Device_Type":6,"Device_Type_Description":"Thermostat Setpoint","Device_SubType":1,"Device_SubType_Description":"Heating 1"},"device_image":""}]}
                                Cooling Temperature Setpoint:
                                {"Name":"HomeSeer Devices","Version":"1.0","Devices":[{"ref":354,"name":"Downstairs Cooling Setpoint","location":"Kennesaw","location2":"Kennesaw Thermostats","value":76,"status":"76 F","device_type_string":"Z-Wave Cooling 1 Setpoint","last_change":"\/Date(1425932829256)\/","relationship":4,"hide_from_view":false,"associated_devices":[301],"device_type":{"Device_API":16,"Device_API_Description":"Thermostat API","Device_Type":6,"Device_Type_Description":"Thermostat Setpoint","Device_SubType":2,"Device_SubType_Description":"Cooling 1"},"device_image":""}]}
                                Battery Level:
                                {"Name":"HomeSeer Devices","Version":"1.0","Devices":[{"ref":365,"name":"Downstairs Battery Level","location":"Kennesaw","location2":"Kennesaw Thermostats","value":100,"status":"100%","device_type_string":"Z-Wave Battery","last_change":"\/Date(1417602472733)\/","relationship":4,"hide_from_view":false,"associated_devices":[301],"device_type":{"Device_API":4,"Device_API_Description":"Plug-In API","Device_Type":0,"Device_Type_Description":"Plug-In Type 0","Device_SubType":128,"Device_SubType_Description":""},"device_image":""}]}
                                Fan Status:
                                {"Name":"HomeSeer Devices","Version":"1.0","Devices":[{"ref":366,"name":"Downstairs Fan State","location":"Kennesaw","location2":"Kennesaw Thermostats","value":0,"status":"Off","device_type_string":"Z-Wave Fan State","last_change":"\/Date(1417602472903)\/","relationship":4,"hide_from_view":false,"associated_devices":[301],"device_type":{"Device_API":16,"Device_API_Description":"Thermostat API","Device_Type":5,"Device_Type_Description":"Thermostat Fan Status","Device_SubType":0,"Device_SubType_Description":"Fan Status"},"device_image":""}]}
                                Relative Humidity:
                                {"Name":"HomeSeer Devices","Version":"1.0","Devices":[{"ref":402,"name":"Downstairs Relative Humidity","location":"Kennesaw","location2":"Kennesaw Thermostats","value":40,"status":"40 %","device_type_string":"Z-Wave Relative Humidity","last_change":"\/Date(1425989474434)\/","relationship":4,"hide_from_view":false,"associated_devices":[301],"device_type":{"Device_API":16,"Device_API_Description":"Thermostat API","Device_Type":2,"Device_Type_Description":"Thermostat Temperature","Device_SubType":5,"Device_SubType_Description":"Relative Humidity"},"device_image":""}]}
