Volume from BLRussound as a Multiswitch?
  • Volume from BLRussound as a Multiswitch?
    Hi there I currently use the BLRussound plugin to control my Russound. I have the volume working correctly now as a slider but ot doesn't give me the granularity I want so I was hoping to use the Multiswitch option to set the value directly. I set up the control as a Multiswitch and it seems to work okay within IMperihome but it doesn't actually control the volume. If I use it as a slider it works fine in Imperihome.
    Here is the control:
    could you set the log level to Trace, and post here the logs you get when you try to use this multiswitch. Thanks
      Okay, attached the log. Not entirely sure if I did that correctly.
      I did 2 Imperihome Volume changes using the multi switch. one set to 13 and the other to 40.
        I don't see any attached file
          hmmm strange... uploads are failing for me on 2 different computers.
          Uploaded to my dropbox instead.
          Thanks for your help!
          https://www.dropbox.com/s/k0osqwd5qj...0Copy.zip?dl=0
            instead of the whole log database could you copy/paste here (or in a txt file) the log lines you get when you try to use the multiswitch, there should not be a lot of lines.
              Okay... how is this?
              Mar-04 9:55:26 AM	 	ImperiHome	TRACE ISSServer Response: {"success":false,"errormsg":"can't find 40 control for device 857"}
              Mar-04 9:55:26 AM	 	ImperiHome	ERROR can't find 40 control for device 857
              Mar-04 9:55:26 AM	 	ImperiHome	TRACE ISSServer Request: /issapi/devices/M12/action/setChoice/40
              Mar-04 9:55:26 AM	 	ImperiHome	TRACE ISSServer Response: {"devices":[{"id":"D279","name":"Evolve Switch Binary","room":"LZ-Wave","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"1"}]},{"id":"D280","name":"Table Lamps","room":"LLiving Room","type":"DevDimmer","params":[{"key":"Level","value":"0"},{"key":"Status","value":"0"}]},{"id":"D6","name":"Light","room":"LWine Room","type":"DevDimmer","params":[{"key":"Level","value":"0"},{"key":"Status","value":"0"}]},{"id":"D838","name":"SS5-Wine Room Heater","room":"LWine Room","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D844","name":"SS4-Tree Lights","room":"LLiving Room","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"1"}]},{"id":"D291","name":"Dining Fireplace","room":"LKitchen","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D852","name":"c1 All Keypads","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D854","name":"Power-Kitchen","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"1"}]},{"id":"D300","name":"Patio Lanterns","room":"LLiving Room","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D857","name":"Volume-Kitchen","room":"LBLRussound","type":"DevDimmer","params":[{"key":"Level","value":"19"},{"key":"Status","value":"1"}]},{"id":"D303","name":"Kitchen Acc Lights","room":"LKitchen","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D307","name":"HDMI Switch","room":"LAV Control","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"1"}]},{"id":"D862","name":"Loudness","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"1"}]},{"id":"D863","name":"Do Not Disturb","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D864","name":"Party Mode","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D865","name":"Party Master","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D869","name":"Power-North Deck","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D40","name":"Thermostat","room":"LKitchen","type":"DevThermostat","params":[{"key":"curfanmode","value":"Auto"},{"key":"availablefanmodes","value":"Auto,On"},{"key":"curmode","value":"Heat"},{"key":"availablemodes","value":"Off,Heat,Cool,Auto"},{"key":"cursetpoint","value":"20"},{"key":"cursetpoint1","value":"31"},{"key":"curtemp","value":"18.6111111111111","unit":"C"},{"key":"cursetpointindex","value":"0"}]},{"id":"D877","name":"Loudness","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D878","name":"Do Not Disturb","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D879","name":"Party Mode","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D880","name":"Party Master","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D50","name":"Thermostat","room":"LWine Room","type":"DevThermostat","params":[{"key":"curtemp","value":"12.5","unit":"C"},{"key":"curfanmode","value":"Auto"},{"key":"availablefanmodes","value":"Auto,On"},{"key":"curmode","value":"Heat"},{"key":"availablemodes","value":"Off,Heat,Cool,Auto"},{"key":"cursetpoint","value":"12.2222222222222"},{"key":"cursetpoint1","value":"30"},{"key":"cursetpointindex","value":"0"}]},{"id":"D884","name":"Power-Bathroom","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D892","name":"Loudness","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"1"}]},{"id":"D893","name":"Do Not Disturb","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D894","name":"Party Mode","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D895","name":"Party Master","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D65","name":"Switch Binary","room":"LMain","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D899","name":"Power","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D907","name":"Loudness","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D908","name":"Do Not Disturb","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D909","name":"Party Mode","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D910","name":"Party Master","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D914","name":"Power-Darts","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D84","name":"Door Lock","room":"LKitchen","type":"DevLock","params":[{"key":"Status","value":"1"}]},{"id":"D922","name":"Loudness","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D923","name":"Do Not Disturb","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D924","name":"Party Mode","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D925","name":"Party Master","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D929","name":"Power-Garage","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D99","name":"SS3-","room":"LServer Room","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"1"}]},{"id":"D937","name":"Loudness","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"1"}]},{"id":"D938","name":"Do Not Disturb","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D939","name":"Party Mode","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D940","name":"Party Master","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D664","name":"Front Door Lock","room":"LLiving Room","type":"DevLock","params":[{"key":"Status","value":"0"}]},{"id":"D110","name":"Irrigation-Front-SS2","room":"LOutside","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D115","name":"Irrigation-East-SS1","room":"LOutside","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D119","name":"Switch Binary 1","room":"LZ-Wave","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D120","name":"Server Room Light","room":"LServer Room","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D675","name":"Thermostat","room":"LBasement-HS","type":"DevThermostat","params":[{"key":"curfanmode","value":"On"},{"key":"availablefanmodes","value":"Auto,On"},{"key":"curmode","value":"Heat"},{"key":"availablemodes","value":"Off,Heat,Cool,Auto"},{"key":"cursetpoint","value":"20"},{"key":"cursetpoint1","value":"30"},{"key":"curtemp","value":"18.6111111111111","unit":"C"},{"key":"cursetpointindex","value":"0"}]},{"id":"D958","name":"Power-Den","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D127","name":"Switch Binary 2","room":"LZ-Wave","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D130","name":"Switch Binary 3","room":"LZ-Wave","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D133","name":"Switch Binary 4","room":"LZ-Wave","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D966","name":"Loudness","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"1"}]},{"id":"D967","name":"Do Not Disturb","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D968","name":"Party Mode","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D969","name":"Party Master","room":"LBLRussound","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D695","name":"Thermostat","room":"LLiving Room","type":"DevThermostat","params":[{"key":"curfanmode","value":"On"},{"key":"availablefanmodes","value":"Auto,On"},{"key":"curmode","value":"Auto"},{"key":"availablemodes","value":"Off,Heat,Cool,Auto"},{"key":"cursetpoint","value":"20"},{"key":"cursetpoint1","value":"23.8888888888889"},{"key":"curtemp","value":"20","unit":"C"},{"key":"cursetpointindex","value":"0"}]},{"id":"D980","name":"Garage Door","room":"LGarage","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D706","name":"Wine Cabinet","room":"LLiving Room","type":"DevDimmer","params":[{"key":"Level","value":"0"},{"key":"Status","value":"0"}]},{"id":"D707","name":"Fireplace Fan","room":"LLiving Room","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D986","name":"Kitchen Light","room":"LKitchen","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D987","name":"Dining Room","room":"LKitchen","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D160","name":"SS6-HTPC","room":"LAV Control","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"1"}]},{"id":"D165","name":"SS7-Office Accs","room":"LDen","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"1"}]},{"id":"D720","name":"Thermostat","room":"LLoft","type":"DevThermostat","params":[{"key":"curfanmode","value":"Unknown"},{"key":"availablefanmodes","value":"Auto,On"},{"key":"curmode","value":"Unknown"},{"key":"availablemodes","value":"Off,Heat,Cool,Auto"},{"key":"cursetpoint","value":"14"},{"key":"cursetpoint1","value":"31"},{"key":"curtemp","value":"0","unit":"C"}]},{"id":"D730","name":"Fireplace","room":"LLiving Room","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D732","name":"Keg CO2","room":"LBasement-HS","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"1"}]},{"id":"D733","name":"Keg Tower Fan","room":"LBasement-HS","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"1"}]},{"id":"D749","name":"SS-Loft Switch","room":"LLoft","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D252","name":"Living Room-Audio-Power","room":"LAV Control","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D254","name":"East Deck-Power","room":"LAV Control","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D258","name":"Living Room-Music","room":"LAV Control","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D259","name":"Living Room-Video","room":"LAV Control","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"1"}]},{"id":"D260","name":"Living Room-Shaw Box","room":"LAV Control","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D261","name":"TV-Power","room":"LAV Control","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D262","name":"Projector-Power","room":"LAV Control","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":"0"}]},{"id":"D266","name":"Thermostat","room":"LMain","type":"DevThermostat","params":[{"key":"curfanmode","value":"Auto"},{"key":"availablefanmodes","value":"Auto,On"},{"key":"curmode","value":"Heat"},{"key":"availablemodes","value":"Off,Heat,Cool,Auto"},{"key":"cursetpoint","value":"20"},{"key":"cursetpoint1","value":"29.5"},{"key":"curtemp","value":"19.7222222222222","unit":"C"},{"key":"cursetpointindex","value":"0"}]},{"id":"Y1","name":"Front Door Lock","room":"LLiving Room","type":"DevDoor","params":[{"key":"Tripped","value":"1"},{"key":"lasttrip","value":"1488642340817"}]},{"id":"Y2","name":"Laundry Lock","room":"LBasement-HS","type":"DevDoor","params":[{"key":"Tripped","value":"0"},{"key":"lasttrip","value":"1488597303706"}]},{"id":"S13","name":"Temperature-Office","room":"LDen","type":"DevGenericSensor","params":[{"key":"Value","value":"18 C","unit":"","graphable":false}]},{"id":"S15","name":"Wine Temp","room":"LWine Room","type":"DevGenericSensor","params":[{"key":"Value","value":"13.1 C","unit":"","graphable":false}]},{"id":"S16","name":"Current Temp","room":"LUltraWeatherWU3 Plugin","type":"DevGenericSensor","params":[{"key":"Value","value":"4 C","unit":"","graphable":false}]},{"id":"S17","name":"S1 Root","room":"LUltraWeatherWU3 Plugin","type":"DevGenericSensor","params":[{"key":"Value","value":"0","unit":"","graphable":false}]},{"id":"M1","name":"Heat Set","room":"LLiving Room","type":"DevMultiSwitch","params":[{"key":"Value","value":"20"},{"key":"Choices","value":"20,19,18,17,16,21,22,23,15,14"}]},{"id":"M2","name":"Source-Bathroom","room":"LBLRussound","type":"DevMultiSwitch","params":[{"key":"Value","value":"Streamer"},{"key":"Choices","value":"JR_Music,Streamer,Logitech_BT,Chromecast"}]},{"id":"M3","name":"Source-Darts","room":"LBLRussound","type":"DevMultiSwitch","params":[{"key":"Value","value":"JR_Music"},{"key":"Choices","value":"JR_Music,Streamer,Logitech_BT,Chromecast"}]},{"id":"M4","name":"Source-Den","room":"LBLRussound","type":"DevMultiSwitch","params":[{"key":"Value","value":"JR_Music"},{"key":"Choices","value":"JR_Music,Streamer,Logitech_BT,Chromecast"}]},{"id":"M5","name":"Source-Garage","room":"LBLRussound","type":"DevMultiSwitch","params":[{"key":"Value","value":"JR_Music"},{"key":"Choices","value":"JR_Music,Streamer,Logitech_BT,Chromecast"}]},{"id":"M6","name":"Source-Kitchen","room":"LBLRussound","type":"DevMultiSwitch","params":[{"key":"Value","value":"JR_Music"},{"key":"Choices","value":"JR_Music,Streamer,Logitech_BT,Chromecast"}]},{"id":"M7","name":"Source-North Deck","room":"LBLRussound","type":"DevMultiSwitch","params":[{"key":"Value","value":"JR_Music"},{"key":"Choices","value":"JR_Music,Streamer,Logitech_BT,Chromecast"}]},{"id":"M9","name":"Volume-North Deck","room":"LBLRussound","type":"DevMultiSwitch","params":[{"key":"Value","value":"0"},{"key":"Choices","value":"Increase,Decrease,15,20,25,30,35,40,45,50,55,60,65,70,75,80,85,90,95,99"}]},{"id":"M10","name":"Volume-Garage","room":"LBLRussound","type":"DevMultiSwitch","params":[{"key":"Value","value":"40"},{"key":"Choices","value":"Increase,Decrease,15,20,25,30,35,40,45,50,55,60,65,70,75,80,85,90,95,99"}]},{"id":"M12","name":"Volume-Kitchen","room":"LBLRussound","type":"DevMultiSwitch","params":[{"key":"Value","value":"20"},{"key":"Choices","value":"Increase,Decrease,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79,80,81,82,83,84,85,86,87,88,89,90,91,92,93,94,95,96,97,98,99,Off,On"}]},{"id":"E8917","name":"Kitchen-PowerOn","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2016-12-15 17:40:34"}]},{"id":"E3353","name":"Music-Next","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-03 19:08:23"}]},{"id":"E7255","name":"TEST-RS-Next from Keypad","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2016-11-13 21:50:28"}]},{"id":"E9496","name":"Integra2-PowerOn - DRULE","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2016-07-19 23:21:57"}]},{"id":"E8382","name":"GoodAfternoon Weekday","room":"G1946758328","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-03 16:00:00"}]},{"id":"E1143","name":"Wine Room Battery","room":"G86323836","type":"DevScene","params":[{"key":"LastRun","value":"2017-02-12 11:51:11"}]},{"id":"E4497","name":"Warm Wine Room","room":"G191629578","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-01 23:07:45"}]},{"id":"E7842","name":"Test send to keypad","room":"G700010673","type":"DevScene","params":[{"key":"LastRun","value":"2016-12-19 21:39:20"}]},{"id":"E4516","name":"TEST-RS-Play Keypad","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2016-11-13 21:50:28"}]},{"id":"E2848","name":"BenqOff","room":"G628597004","type":"DevScene","params":[{"key":"LastRun","value":"2017-01-27 19:21:57"}]},{"id":"E2865","name":"Russ-Z1-VolUp","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2016-08-23 23:17:11"}]},{"id":"E7323","name":"Good night","room":"G1946758328","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-02 23:30:00"}]},{"id":"E8442","name":"BenqOn","room":"G628597004","type":"DevScene","params":[{"key":"LastRun","value":"2017-01-27 19:18:41"}]},{"id":"E2887","name":"Russ-Z7 Power SyncOn","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2017-01-27 16:33:00"}]},{"id":"E9574","name":"Music-Prev","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-01 20:25:41"}]},{"id":"E105","name":"Fireplace On","room":"G412793405","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-03 18:39:34"}]},{"id":"E9582","name":"Trigger check if door changes","room":"G191629578","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-03 16:38:18"}]},{"id":"E4570","name":"Fireplace Off","room":"G412793405","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-03 19:14:45"}]},{"id":"E7921","name":"Dining Room Thermostat Battery","room":"G86323836","type":"DevScene","params":[{"key":"LastRun","value":"2017-01-31 10:54:50"}]},{"id":"E9594","name":"Get Taps Ready","room":"G1946758328","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-03 16:00:00"}]},{"id":"E4581","name":"Movie Lights","room":"G1946758328","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-01 18:55:03"}]},{"id":"E7925","name":"East Deck-PowerOff","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2017-02-11 18:56:19"}]},{"id":"E5705","name":"EG-HDMI-Shaw","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2016-08-02 22:05:39"}]},{"id":"E2921","name":"Integra2-PowerOn","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2016-07-05 13:19:48"}]},{"id":"E9615","name":"HDMI-PowerOn","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2016-10-12 21:20:18"}]},{"id":"E6841","name":"Wine Room Heater Off","room":"G412793405","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-02 07:08:50"}]},{"id":"E4624","name":"Xmas Outside Off","room":"G1946758328","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-03 01:00:00"}]},{"id":"E9641","name":"EG-HDMI-Video","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2016-08-02 22:05:28"}]},{"id":"E3517","name":"Wine Room Lights - Auto On","room":"G1946758328","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-02 12:39:01"}]},{"id":"E9094","name":"Living Room-PowerOff","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-03 19:01:21"}]},{"id":"E2414","name":"Office Off","room":"G1946758328","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-03 01:00:00"}]},{"id":"E6872","name":"EG-HDMI-Power","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2016-10-12 21:20:18"}]},{"id":"E2419","name":"Weekly Battery Report","room":"G86323836","type":"DevScene","params":[{"key":"LastRun","value":"2017-02-28 06:00:00"}]},{"id":"E6330","name":"Garage Door is Open after 10","room":"G191629578","type":"DevScene","params":[{"key":"LastRun","value":"2017-01-31 10:38:35"}]},{"id":"E5221","name":"Irrigate-Front","room":"G1975290173","type":"DevScene","params":[{"key":"LastRun","value":"2016-08-28 07:00:59"}]},{"id":"E1883","name":"Kitchen-VolumeDown","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-01 20:25:32"}]},{"id":"E1885","name":"Laundry Door Battery","room":"G86323836","type":"DevScene","params":[{"key":"LastRun","value":"2017-02-01 13:21:07"}]},{"id":"E5785","name":"TV-Off if Projector On","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-01 22:17:44"}]},{"id":"E1329","name":"East Deck-VolumeUp","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2017-02-11 18:52:24"}]},{"id":"E4122","name":"NorthDeckVolumeDown","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2017-02-19 18:16:33"}]},{"id":"E780","name":"Russ-Z1 Power SyncOff","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-01 16:23:26"}]},{"id":"E3010","name":"Front Door Battery","room":"G86323836","type":"DevScene","params":[{"key":"LastRun","value":"2017-02-01 09:40:16"}]},{"id":"E6911","name":"TV-On","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-02 17:45:04"}]},{"id":"E9142","name":"Russ-Z7 Power SyncOff","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-01 16:23:28"}]},{"id":"E4150","name":"GoodMorning Weekday 9am","room":"G1946758328","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-03 09:00:00"}]},{"id":"E808","name":"Projector-On","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-01 22:17:44"}]},{"id":"E6959","name":"Server Room Light","room":"G1946758328","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-03 19:19:08"}]},{"id":"E3626","name":"Kitchen-PowerOff","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2016-12-15 23:30:00"}]},{"id":"E6972","name":"Evening Lights","room":"G1946758328","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-03 17:25:23"}]},{"id":"E847","name":"Projector-Off","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-01 22:17:51"}]},{"id":"E5868","name":"Russ-Z1 Power SyncOn","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-01 18:40:09"}]},{"id":"E8655","name":"Weather","room":"G628597004","type":"DevScene","params":[{"key":"LastRun","value":"0001-01-01 00:00:00"}]},{"id":"E4213","name":"Office On","room":"G1946758328","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-03 05:45:00"}]},{"id":"E9786","name":"LivingRoom-Video","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-02 19:40:12"}]},{"id":"E9791","name":"Wine Room Heater On","room":"G412793405","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-02 07:03:59"}]},{"id":"E4221","name":"NorthDeckVolumeUp","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2017-02-19 17:56:28"}]},{"id":"E5338","name":"Audio On with TV","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-02 17:44:36"}]},{"id":"E9241","name":"East Deck-VolumeDown","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2017-02-11 18:52:27"}]},{"id":"E8128","name":"Master Heat Set","room":"G412793405","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-03 18:39:24"}]},{"id":"E330","name":"GarageVolume-Down","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2016-08-04 15:33:25"}]},{"id":"E2004","name":"GoodMorning Weekday","room":"G1946758328","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-03 06:00:00"}]},{"id":"E2564","name":"Living Room Thermostat Battery","room":"G86323836","type":"DevScene","params":[{"key":"LastRun","value":"2017-01-31 10:53:25"}]},{"id":"E9259","name":"Movie Lights-Auto Run","room":"G1946758328","type":"DevScene","params":[{"key":"LastRun","value":"2016-12-23 22:03:06"}]},{"id":"E3133","name":"Poll Temps","room":"G412793405","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-02 15:16:12"}]},{"id":"E6478","name":"Main Thermostat Battery","room":"G86323836","type":"DevScene","params":[{"key":"LastRun","value":"2017-01-31 10:56:26"}]},{"id":"E356","name":"GoodMorning Weekday - Loft","room":"G412793405","type":"DevScene","params":[{"key":"LastRun","value":"2017-02-14 09:52:57"}]},{"id":"E9831","name":"Bathroom-Default Music","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2016-12-26 10:16:59"}]},{"id":"E7622","name":"Turn Loft Heater On","room":"G412793405","type":"DevScene","params":[{"key":"LastRun","value":"2017-02-09 03:00:03"}]},{"id":"E2053","name":"Living Room-VolumeDown","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-02 20:31:31"}]},{"id":"E8751","name":"Russ-Z1-VolDown","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2016-08-23 23:19:09"}]},{"id":"E4302","name":"LivingRoom-Music","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-02 19:01:44"}]},{"id":"E1517","name":"North Deck-PowerOff","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2016-12-15 17:40:29"}]},{"id":"E6531","name":"Basement Thermostat Battery","room":"G86323836","type":"DevScene","params":[{"key":"LastRun","value":"2017-01-31 10:59:04"}]},{"id":"E7091","name":"Movie Lights-Auto Reset","room":"G1946758328","type":"DevScene","params":[{"key":"LastRun","value":"2016-12-26 11:48:21"}]},{"id":"E4864","name":"Lock Or Door Open","room":"G191629578","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-03 19:15:06"}]},{"id":"E3754","name":"Integra2-PowerOff","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2016-07-07 00:24:15"}]},{"id":"E424","name":"Locks OKAY?","room":"G191629578","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-03 16:38:18"}]},{"id":"E1542","name":"Cold Wine Room","room":"G191629578","type":"DevScene","params":[{"key":"LastRun","value":"2017-02-28 10:26:17"}]},{"id":"E8786","name":"Turn Loft Heat Off","room":"G412793405","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-02 22:45:00"}]},{"id":"E6002","name":"Irrigate-East","room":"G1975290173","type":"DevScene","params":[{"key":"LastRun","value":"2016-08-29 07:00:59"}]},{"id":"E7123","name":"North Deck-PowerOn","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2016-12-15 17:40:18"}]},{"id":"E6568","name":"Living Room-VolumeUp","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-03 15:48:46"}]},{"id":"E5455","name":"Living Room-PowerOn","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-03 15:45:10"}]},{"id":"E2117","name":"Kitchen-VolumeUp","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-03 18:43:13"}]},{"id":"E451","name":"Living Room-PowerOn-Auto","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-02 17:44:36"}]},{"id":"E4364","name":"GarageVolume-Up","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2016-08-04 11:09:37"}]},{"id":"E9383","name":"Music-Play","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-02 18:51:02"}]},{"id":"E472","name":"EG Test","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2016-07-06 20:34:44"}]},{"id":"E3819","name":"Office Lights - Auto On","room":"G1946758328","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-03 18:04:26"}]},{"id":"E2707","name":"Garage Door-Open","room":"G1946758328","type":"DevScene","params":[{"key":"LastRun","value":"2017-02-21 19:09:53"}]},{"id":"E6082","name":"Loft Thermostat Battery","room":"G86323836","type":"DevScene","params":[{"key":"LastRun","value":"2017-02-09 00:40:26"}]},{"id":"E2202","name":"Office Lights - Auto Off","room":"G1946758328","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-03 18:06:55"}]},{"id":"E4433","name":"Garage Door-Close","room":"G1946758328","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-03 10:08:01"}]},{"id":"E5549","name":"LivingRoom-ShawBox","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-02 17:45:42"}]},{"id":"E1102","name":"East Deck-PowerOn","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2017-02-11 18:52:19"}]},{"id":"E2781","name":"TV-Off","room":"G193360283","type":"DevScene","params":[{"key":"LastRun","value":"2017-03-02 17:44:58"}]}]}
                it's a bug, I will try to fix it. Thanks for reporting!
                  Ok.
                  Thanks for being so responsive!
                  Cheers!
                    It is fixed in version 3.0.0.20 of the plug-in available in the Beta section of the updater. Please test and let me know.
                      Hi Spud,
                      I was away on vacation but I just got back and tested this today and it is working as expected now with the new beta installed.
                      Thank you so much!
