Problem HeatIT thermostat
  • olof
    Thanks Spud, that works for me. Set the energy saving to 50 and now it controls the correct set point
  • spud
    Originally posted by olof View Post
    When I click I can set both the temperatures so don't have the issue that gjelsvik is reporting. So only issue I have is that the main tempreature setting is defaulting to the energy save heating set point instead of the normal heat setpoint
    When there is multiple setpoints the plug-in choose the one the closest to the ambient temp as the default one. So if you don't use the "Energy Save haeting set point" at all set it to a value far from the ambient temp.
  • olof
  • gjelsvik
    I have the same problem
    IH sends the space as a '+' so you will need to rename the "Energy Save Heat" status to "Energy+save+heat" then it will work.
    I made a simillir topic about this before the weekend.
  • spud
    when you tap on the themorstat widget from IH, do you see one or 2 setpoints. If 2 can you control the normal setpoint from there?
    regarding the mode that doesn't work, does it have a pace in it? if so this will be fixed in the next version, the workaround is to remove the space from the label.
  • olof
    Screenshot
  • olof
    started a topic Problem HeatIT thermostat
    Hi there,
    I have two issues with the HeatIT thermostat.
    The most important one is that it is setting the energy safe heating setpoint and I want it to set the normal heat setpoint (maybe make it configurable in the config...) second issue is I cannot set it to the energy saving mode only to heat mode so basically cannot use the HeatIT with ImperiHome at the moment
    Olof
