Originally posted by MrBoo
View Post
Imperihome Envisalink issues
Originally posted by spud View PostIt seems that the plug-in does not receive anything in the case it fails.
Since you said it worked with the Disarm control, I guess the problem may be the space in the "Arm Stay" control. Could you edit your partition device, go to the "status graphics" tab and change "Arm Stay" to "Arm_Stay". Then you will need to restart the IH plug-in (or click the rebuild cache button) for the change to propagate to IH.
Let me know how it goes, thanks
I tried both the Arm_Stay and Arm_Away and both did the same thing. It acts different when remote and the options fail (before the description change and now as well). The widget will display the selected option as a status for a few seconds (Say, Arm Away or Arm_Away) then changes back to Ready.
Originally posted by MrBoo View PostThanks so much for your help. I was able to disable MyHS and reenable to see the proper settings. I've done a lot of research but I had not seen that fix.
I believe it is safe to say that not seeing the option wasn't a deal breaker as I did not do the custom settings and the default was probably still there. I connected just fine without seeing the settings before. making that change did not have an affect on this issue.
I tried to clear the screen, change to trace, run the option, then freeze the results to limit data. I also did a little house keeping to remove overly personal cam settings. I have two files. One with this process while my Android was attached to my local LAN and one with Wifi turned off. The files are named accordingly. I am sure you are much better at wading through these logs than I am! ha!
PS I tried a few times on the failure so the file got too large. I trimmed some data our but I am sure one or more of the tries are in there. If not, I can split the original into two.
Originally posted by MrBoo View PostI saw the remote config in the user manual, but figured the plugin had changed since then. I do have a custom http option but I do not have a myHS area.
Originally posted by MrBoo View PostWhat areas are you looking for from the trace? I turned it on and it flooded with data. I can parse out the stuff you do not need.
Originally posted by spud View PostI may be wrong, but I don't think you can use dynamic icons with multi-switchs. You may want to ask (or request this feature to be added) directly to IH support.
Originally posted by spud View PostStrange one indeed!
How is the plug-in configured? Do you use the "Custom http server" or myHS ?
Could you set the log level to Trace, and post the logs you get when you try to arm from local LAN, and then while remote?
Originally posted by MrBoo View PostI have the panel set as a multi switch and I see the switch just fine in Imperihome. I can see status changes and I can change the icons, but I cannot figure out how to get the icons to change (or change colors) as the panel status changes. It isn't a huge issue but I use an old phone as an alarm status by my front door and to give TTS for certain notifications. Seeing red or orange means do not open the front door. Ha!
Originally posted by MrBoo View PostNext, and this is a strange one, communication seem great for both local LAN and remote connection in Imperihome. Status changes are fine, device changes (turn lights on off etc), and run events work for both local and abroad for everything but the panel. With the panel, everything works great local LAN but I can not arm stay or arm away while remote (off the local LAN). The strange thing is, I can disarm remote just fine so at least one function on the widget works both local and remote. I can do everything including arm stay or arm away just fine local LAN with the widget.
I am really new to Homeseer (First post here) but a long time HA user (Vera). I have almost everything working well, but I have two small issues with Imperihome (Android) and Envisalink 3 (DSC panel).
Current Date/Time: 5/16/2017 9:17:58 PM
HomeSeer Version: HS3 Standard Edition 3.0.0.318
System Uptime: 0 Days 14 Hours 39 Minutes 42 Seconds
IP Address: 192.168.1.3
Number of Devices: 112
Number of Events: 43
Available Threads: 200
Enabled Plug-Ins
3.0.22.30668: Blue-Iris
3.0.0.32: EasyTrigger
3.0.0.33: EnvisaLink
1.1.6.0: Honeywell WiFi Thermostat
3.0.0.68: HSTouch Server
3.0.1.1: IFTTT
3.0.0.20: ImperiHome
3.0.0.63: weatherXML
3.0.1.87: Z-WaveTags: None
