Contacting HomeSeer This Week
See more
See less
Can't connect to ImperiHome remotely from Android
  • #31
    Originally posted by ufd108 View Post
    Ok, tried it locally with same results. And I looked in the logs directory and there is no ImperiHome.txt file. I double-checked the plug-in settings, and they look correct, but I guess I'm doing something wrong.
    Have you enabled the "Log To File" option from the config page?
    What base url do you set in your IH settings?
    What are your settings for the HS Web server, could you post a screenshot of Tools > Setup > Network > Web Server Settings
    • #32
      Ok, I got it working (at least locally; I haven't tried remotely yet but I'm guessing that is going to work). All I did was delete all the connection information and re-type it in. Same info, but something must have gotten corrupted. Once I re-entered all the connection information, I was able to re-connect.
      It must not have been connecting correctly for a while. I had replaced a few switches in the last couple of months, and the changes weren't detected (I hadn't thought to update the ImperiHome cache). But when I just now connected, all the new switches came up as errors, since they aren't the old devices, and I had to remove them and re-enter the new switches. So in the long run, this cleaned up something that wasn't working correctly.
      Anyway, I'm up and running now. Thanks for the assistance!
      • #33
        I loaded the beta version 3.0.0.24
        Same result. Works locally but wont work remote with or without wifi
        I have an exclamation point in my myhs password
        I'm using android app 3.0.4
        Here's a snippit of ImperiHome.txt (it's 916kb)
        Sep-26 16:16:12 DEBUG Device 225 value changed from 0 to 100
        Sep-26 16:16:12 DEBUG ISSCache: Device SG ASCII Ack-Flags (ref=225) added or updated
        Sep-26 16:16:13 DEBUG Device 225 value changed from 100 to 0
        Sep-26 16:16:13 DEBUG ISSCache: Device SG ASCII Ack-Flags (ref=225) added or updated
        Sep-26 16:16:55 TRACE ISSServer Request: /issapi/devices
        Sep-26 16:16:55 TRACE ISSServer Response: {"devices":[{"id":"D277","name":"Alarm Panic","room":"LSecurity","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":" 0"}]},{"id":"D278","name":"Page (DI-5)","room":"LAnnounce","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":" 0"}]},{"id":"D280","name":"DDS ByPass Flag","room":"LDDS","type":"DevSwitch","params":[{"key":"pulseable","value":"0"},{"key":"Status","value":" 1"}]},{"id":"D281","name":"New Device","room":"LUnknown","type":"DevSwitch","params":
        • #34
          Is this log snippet from the time you successfully connected locally, or when you try to connect remotely?
          I need to know if you see any
          TRACE ISSServer Request....
          or
          TRACE ISSServer Response...
          in your logs when you try to connect remotely
          • #35
            I deleted the log file, de-selected log-to-file and then selected log-to-file and then quickly attempted to connect from the phone and got this
            Forced Remote is checked
            I went through the configuration routine by clicking Finish and then back button back to my main page then hit refresh. I still get the same Error message "could not get the devices infos" when I do the refresh
            Sep-26 17:40:45 TRACE ISSServer Request: /issapi/system
            Sep-26 17:40:45 TRACE ISSServer Response: {"id":"HS3 PC","apiversion":1}
            Sep-26 17:40:50 TRACE ISSServer Request: /issapi/system
            Sep-26 17:40:50 TRACE ISSServer Response: {"id":"HS3 PC","apiversion":1}
            Sep-26 17:40:55 DEBUG Device 207 value changed from 0 to 100
            Sep-26 17:40:55 DEBUG ISSCache: Device SG ASCII Ack-Relay (ref=207) added or updated
            Sep-26 17:40:56 DEBUG Device 207 value changed from 100 to 0
            Sep-26 17:40:56 DEBUG ISSCache: Device SG ASCII Ack-Relay (ref=207) added or updated
            You mentioned that you used the Imperihome Android app 3.0.5. The version is not available in the Google store. Where can I get it? Maybe it will solve the problem.
            You also asked if I was using a special character in my password for myhs. I am using an exclamation point. I was going to try and change the password, but it requires at least one special character. Why were you asking about special characters? Is it because you are using some sort of delimiter character and it might cause a problem if I used the same one?
            • #36
              Is that all you have in the log file, when you try to connect with forced remote?
              It's strange that you receive the /issapi/system request but not the /issapi/devices request.
              I have 3.0.5 probably because I'm a beta tester, but I doubt this is the cause of the problem, it worked for me with previous version and it works for a lot of other users
              Re special characters, I was just guessing what could be wrong but I tried with an exclamation point and it worked for me. The plugin does not handle any of the user/password authentication, this is all done between myhs and the IH app, this is why it's very difficult for me to help you.
              The fact that the plugin receives the system request would indicate that the authentication is ok, but I don't know why would it not receive subsequent requests.
              Do you have any iOS or other Android device to test with?
              • #37
                Yes, that is all that was in that file but that's because I stopped the logging too soon. Here it is again after a few minutes. This is a small part of the file. I will try an iPhone and an Android tablet and report the results.
                Sep-27 16:28:10 TRACE ISSServer Request: /issapi/system
                Sep-27 16:28:10 TRACE ISSServer Response: {"id":"HS3 PC","apiversion":1}
                Sep-27 16:28:14 DEBUG Device 225 value changed from 0 to 100
                Sep-27 16:28:14 DEBUG ISSCache: Device SG ASCII Ack-Flags (ref=225) added or updated
                Sep-27 16:28:15 DEBUG Device 225 value changed from 100 to 0
                Sep-27 16:28:15 DEBUG ISSCache: Device SG ASCII Ack-Flags (ref=225) added or updated
                Sep-27 16:28:34 DEBUG Device 235 string changed to <span style="white-space:nowrap; vertical-align:middle;"><span style="white-space:nowrap; display:-moz-inline-box; display:inline-block; vertical-align:middle; width:auto;"><img src="/images/Devices/jon00/Cumulus/Timedate.png" border="0" ></span><span style='white-space:nowrap; display:-moz-inline-box; display:inline-block; vertical-align:middle; padding:3px;'>27/09/17 16:28:27</span></span>
                Sep-27 16:28:34 DEBUG Device 236 value changed from 31 to 30
                Sep-27 16:28:34 DEBUG Device 236 string changed to <span style="white-space:nowrap; vertical-align:middle;"><span style="white-space:nowrap; display:-moz-inline-box; display:inline-block; vertical-align:middle; width:auto;"><img src="/images/Devices/jon00/Cumulus/Humidity.png" border="0" ></span><span style='white-space:nowrap; display:-moz-inline-box; display:inline-block; vertical-align:middle; padding:3px;'>30 %</span></span>
                Sep-27 16:28:34 DEBUG Device 237 value changed from 87.3 to 87.1
                Sep-27 16:28:34 DEBUG ISSCache: Sensor Indoor Temperature (id=42) added or updated
                Sep-27 16:28:34 DEBUG Device 237 string changed to <span style="white-space:nowrap; vertical-align:middle;"><span style="white-space:nowrap; display:-moz-inline-box; display:inline-block; vertical-align:middle; width:auto;"><img src="/images/Devices/jon00/Cumulus/Thermometer.png" border="0" ></span><span style='white-space:nowrap; display:-moz-inline-box; display:inline-block; vertical-align:middle; padding:3px;'>87.1 &deg;F</span></span>
                Sep-27 16:28:34 DEBUG Device 238 value changed from 44 to 43
                Sep-27 16:28:34 DEBUG Device 238 string changed to <span style="white-space:nowrap; vertical-align:middle;"><span style="white-space:nowrap; display:-moz-inline-box; display:inline-block; vertical-align:middle; width:auto;"><img src="/images/Devices/jon00/Cumulus/Humidity.png" border="0" ></span><span style='white-space:nowrap; display:-moz-inline-box; display:inline-block; vertical-align:middle; padding:3px;'>43 %</span></span>
                Sep-27 16:28:34 DEBUG Device 240 value changed from 1.1 to 1
                Sep-27 16:28:34 DEBUG Device 240 string changed to <span style="white-space:nowrap; vertical-align:middle;"><span style="white-space:nowrap; display:-moz-inline-box; display:inline-block; vertical-align:middle; width:auto;"><img src="/images/Devices/jon00/Cumulus/Thermometer.png" border="0" ></span><span style='white-space:nowrap; display:-moz-inline-box; display:inline-block; vertical-align:middle; padding:3px;'>+1.0 &deg; F</span></span>
                Sep-27 16:28:34 DEBUG Device 243 value changed from 79.5 to 79.3
                Sep-27 16:28:34 DEBUG Device 243 string changed to <span style="white-space:nowrap; vertical-align:middle;"><span style="white-space:nowrap; display:-moz-inline-box; display:inline-block; vertical-align:middle; width:auto;"><img src="/images/Devices/jon00/Cumulus/Thermometer.png" border="0" ></span><span style='white-space:nowrap; display:-moz-inline-box; display:inline-block; vertical-align:middle; padding:3px;'>79.3 &deg; at 06:42</span></span>
                Sep-27 16:28:34 DEBUG Device 245 value changed from 54.4 to 53.8
                Sep-27 16:28:34 DEBUG Device 245 string changed to <span style="white-space:nowrap; vertical-align:middle;"><span style="white-space:nowrap; display:-moz-inline-box; display:inline-block; vertical-align:middle; width:auto;"><img src="/images/Devices/jon00/Cumulus/Thermometer.png" border="0" ></span><span style='white-space:nowrap; display:-moz-inline-box; display:inline-block; vertical-align:middle; padding:3px;'>53.8 &deg; F</span></span>
                Sep-27 16:28:34 DEBUG Device 247 value changed from 29.842 to 29.841
                Sep-27 16:28:34 DEBUG Device 247 string changed to <span style="white-space:nowrap; vertical-align:middle;"><span style="white-space:nowrap; display:-moz-inline-box; display:inline-block; vertical-align:middle; width:auto;"><img src="/images/Devices/jon00/Cumulus/Pressure.png" border="0" ></span><span style='white-space:nowrap; display:-moz-inline-box; display:inline-block; vertical-align:middle; padding:3px;'>29.841 in</span></span>
                Sep-27 16:28:34 DEBUG Device 249 value changed from 29.842 to 29.841
                Sep-27 16:28:34 DEBUG Device 249 string changed to <span style="white-space:nowrap; vertical-align:middle;"><span style="white-space:nowrap; display:-moz-inline-box; display:inline-block; vertical-align:middle; width:auto;"><img src="/images/Devices/jon00/Cumulus/Pressure.png" border="0" ></span><span style='white-space:nowrap; display:-moz-inline-box; display:inline-block; vertical-align:middle; padding:3px;'>29.841 in at 16:28</span></span>
                Sep-27 16:28:34 DEBUG Device 251 string changed to <span style="white-space:nowrap; vertical-align:middle;"><span style="white-space:nowrap; display:-moz-inline-box; display:inline-block; vertical-align:middle; width:auto;"><img src="/images/Devices/jon00/Cumulus/Compass.png" border="0" ></span><span style='white-space:nowrap; display:-moz-inline-box; display:inline-block; vertical-align:middle; padding:3px;'>ENE</span></span>
                Sep-27 16:28:34 DEBUG ISSCache: Sensor Wind Speed Latest (id=13) added or updated
                Sep-27 16:28:34 DEBUG Device 253 value changed from 43 to 68
                Sep-27 16:28:35 DEBUG Device 253 string changed to <span style="white-space:nowrap; vertical-align:middle;"><span style="white-space:nowrap; display:-moz-inline-box; display:inline-block; vertical-align:middle; width:auto;"><img src="/images/Devices/jon00/Cumulus/Compass.png" border="0" ></span><span style='white-space:nowrap; display:-moz-inline-box; display:inline-block; vertical-align:middle; padding:3px;'>68</span></span>
                Sep-27 16:28:35 DEBUG Device 259 value changed from 5 to 0
                Sep-27 16:28:35 DEBUG ISSCache: Sensor Wind Speed Latest (id=13) added or updated
                Sep-27 16:28:35 DEBUG Device 259 string changed to <span style="white-space:nowrap; vertical-align:middle;"><span style="white-space:nowrap; display:-moz-inline-box; display:inline-block; vertical-align:middle; width:auto;"><img src="/images/Devices/jon00/Cumulus/windspeed.png" border="0" ></span><span style='white-space:nowrap; display:-moz-inline-box; display:inline-block; vertical-align:middle; padding:3px;'>0 mph</span></span>
                Sep-27 16:28:35 DEBUG Device 262 value changed from 82.5 to 82.2
                Sep-27 16:28:35 DEBUG Device 262 string changed to <span style="white-space:nowrap; vertical-align:middle;"><span style="white-space:nowrap; display:-moz-inline-box; display:inline-block; vertical-align:middle; width:auto;"><img src="/images/Devices/jon00/Cumulus/Humidex.png" border="0" ></span><span style='white-space:nowrap; display:-moz-inline-box; display:inline-block; vertical-align:middle; padding:3px;'>82.2</span></span>
                Sep-27 16:28:35 DEBUG Device 264 value changed from 33 to 32
                Sep-27 16:28:35 DEBUG Device 264 string changed to <span style="white-space:nowrap; vertical-align:middle;"><span style="white-space:nowrap; display:-moz-inline-box; display:inline-block; vertical-align:middle; width:auto;"><img src="/images/Devices/jon00/Cumulus/Solar.png" border="0" ></span><span style='white-space:nowrap; display:-moz-inline-box; display:inline-block; vertical-align:middle; padding:3px;'>32 W/m2</span></span>
                Sep-27 16:28:35 DEBUG Device 265 value changed from 5386 to 5522
                Sep-27 16:28:35 DEBUG Device 265 string changed to <span style="white-space:nowrap; vertical-align:middle;"><span style="white-space:nowrap; display:-moz-inline-box; display:inline-block; vertical-align:middle; width:auto;"><img src="/images/Devices/jon00/Cumulus/Cloudbase.png" border="0" ></span><span style='white-space:nowrap; display:-moz-inline-box; display:inline-block; vertical-align:middle; padding:3px;'>5522 ft</span></span>
                Sep-27 16:29:13 DEBUG Device 305 string changed to <table border='0' cellspacing='0' cellpadding='0' height='35' ><tr><td style='vertical-align: bottom; padding-top:5; background-color:#5e697a; white-space: nowrap; width:150'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='8' Title='3.92 % @ 9/27/2017 4:04:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='7' Title='3.79 % @ 9/27/2017 4:08:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='9' Title='4.26 % @ 9/27/2017 4:14:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='6' Title='3.44 % @ 9/27/2017 4:19:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='7' Title='3.58 % @ 9/27/2017 4:23:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='5' Title='3.32 % @ 9/27/2017 4:28:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='4' Title='3.03 % @ 9/27/2017 4:34:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='5' Title='3.19 % @ 9/27/2017 4:38:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='5' Title='3.19 % @ 9/27/2017 4:43:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='6' Title='3.34 % @ 9/27/2017 4:49:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='9' Title='4.18 % @ 9/27/2017 4:54:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='6' Title='3.54 % @ 9/27/2017 4:58:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='6' Title='3.41 % @ 9/27/2017 5:03:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='5' Title='3.24 % @ 9/27/2017 5:08:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='5' Title='3.22 % @ 9/27/2017 5:13:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='6' Title='3.46 % @ 9/27/2017 5:18:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='8' Title='3.90 % @ 9/27/2017 5:23:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='4' Title='2.89 % @ 9/27/2017 5:28:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='6' Title='3.57 % @ 9/27/2017 5:34:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='10' Title='4.41 % @ 9/27/2017 5:39:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='6' Title='3.51 % @ 9/27/2017 5:43:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='9' Title='4.07 % @ 9/27/2017 5:49:01 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='6' Title='3.51 % @ 9/27/2017 5:54:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='8' Title='3.85 % @ 9/27/2017 5:58:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='6' Title='3.42 % @ 9/27/2017 6:03:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='9' Title='4.28 % @ 9/27/2017 6:08:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='6' Title='3.51 % @ 9/27/2017 6:13:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='4' Title='3.01 % @ 9/27/2017 6:18:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='6' Title='3.54 % @ 9/27/2017 6:23:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='6' Title='3.48 % @ 9/27/2017 6:28:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='7' Title='3.60 % @ 9/27/2017 6:34:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='7' Title='3.72 % @ 9/27/2017 6:39:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='7' Title='3.79 % @ 9/27/2017 6:44:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='5' Title='3.28 % @ 9/27/2017 6:48:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='6' Title='3.38 % @ 9/27/2017 6:53:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='6' Title='3.40 % @ 9/27/2017 6:58:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='6' Title='3.36 % @ 9/27/2017 7:03:58 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='5' Title='3.29 % @ 9/27/2017 7:09:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='8' Title='3.95 % @ 9/27/2017 7:14:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='8' Title='4.00 % @ 9/27/2017 7:18:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='8' Title='3.95 % @ 9/27/2017 7:24:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='7' Title='3.61 % @ 9/27/2017 7:28:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='7' Title='3.65 % @ 9/27/2017 7:34:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='7' Title='3.72 % @ 9/27/2017 7:38:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='6' Title='3.50 % @ 9/27/2017 7:43:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='5' Title='3.12 % @ 9/27/2017 7:48:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='6' Title='3.51 % @ 9/27/2017 7:53:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='5' Title='3.10 % @ 9/27/2017 7:58:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='7' Title='3.74 % @ 9/27/2017 8:03:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='14' Title='5.41 % @ 9/27/2017 8:09:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='8' Title='4.00 % @ 9/27/2017 8:14:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='7' Title='3.64 % @ 9/27/2017 8:19:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='6' Title='3.46 % @ 9/27/2017 8:23:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='7' Title='3.64 % @ 9/27/2017 8:28:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='5' Title='3.23 % @ 9/27/2017 8:34:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='8' Title='3.90 % @ 9/27/2017 8:38:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='8' Title='3.88 % @ 9/27/2017 8:43:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='5' Title='3.24 % @ 9/27/2017 8:48:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='8' Title='4.02 % @ 9/27/2017 8:53:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='8' Title='3.85 % @ 9/27/2017 8:59:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='12' Title='4.96 % @ 9/27/2017 9:04:01 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='10' Title='4.50 % @ 9/27/2017 9:09:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='6' Title='3.37 % @ 9/27/2017 9:14:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='8' Title='3.87 % @ 9/27/2017 9:18:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='15' Title='5.66 % @ 9/27/2017 9:24:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='5' Title='3.27 % @ 9/27/2017 9:28:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='7' Title='3.70 % @ 9/27/2017 9:34:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='13' Title='5.10 % @ 9/27/2017 9:39:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='13' Title='5.19 % @ 9/27/2017 9:44:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='7' Title='3.71 % @ 9/27/2017 9:48:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='6' Title='3.48 % @ 9/27/2017 9:53:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='12' Title='4.95 % @ 9/27/2017 9:59:01 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='5' Title='3.23 % @ 9/27/2017 10:03:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='7' Title='3.67 % @ 9/27/2017 10:08:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='9' Title='4.22 % @ 9/27/2017 10:13:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='11' Title='4.62 % @ 9/27/2017 10:19:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='13' Title='5.15 % @ 9/27/2017 10:24:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='5' Title='3.21 % @ 9/27/2017 10:28:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='7' Title='3.70 % @ 9/27/2017 10:34:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='8' Title='3.88 % @ 9/27/2017 10:39:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='7' Title='3.62 % @ 9/27/2017 10:44:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='8' Title='3.91 % @ 9/27/2017 10:49:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='5' Title='3.16 % @ 9/27/2017 10:54:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='7' Title='3.60 % @ 9/27/2017 10:58:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='11' Title='4.66 % @ 9/27/2017 11:03:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='19' Title='6.46 % @ 9/27/2017 11:09:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='14' Title='5.35 % @ 9/27/2017 11:14:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='15' Title='5.54 % @ 9/27/2017 11:19:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='18' Title='6.32 % @ 9/27/2017 11:24:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='25' Title='7.91 % @ 9/27/2017 11:29:01 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='10' Title='4.45 % @ 9/27/2017 11:34:01 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='10' Title='4.41 % @ 9/27/2017 11:39:00 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='6' Title='3.35 % @ 9/27/2017 11:43:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='5' Title='3.20 % @ 9/27/2017 11:48:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='5' Title='3.29 % @ 9/27/2017 11:53:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='9' Title='4.21 % @ 9/27/2017 11:58:59 AM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='9' Title='4.25 % @ 9/27/2017 12:04:00 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='5' Title='3.21 % @ 9/27/2017 12:08:59 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='8' Title='3.87 % @ 9/27/2017 12:14:00 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='9' Title='4.16 % @ 9/27/2017 12:19:00 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='7' Title='3.71 % @ 9/27/2017 12:24:00 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='13' Title='5.05 % @ 9/27/2017 12:29:00 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='9' Title='4.22 % @ 9/27/2017 12:34:00 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='22' Title='7.40 % @ 9/27/2017 12:39:01 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='6' Title='3.41 % @ 9/27/2017 12:43:59 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='7' Title='3.65 % @ 9/27/2017 12:48:59 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='6' Title='3.40 % @ 9/27/2017 12:53:59 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='9' Title='4.12 % @ 9/27/2017 12:59:00 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='10' Title='4.35 % @ 9/27/2017 1:03:59 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='12' Title='4.86 % @ 9/27/2017 1:09:00 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='14' Title='5.30 % @ 9/27/2017 1:14:00 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='12' Title='4.91 % @ 9/27/2017 1:19:00 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='9' Title='4.17 % @ 9/27/2017 1:23:59 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='7' Title='3.80 % @ 9/27/2017 1:28:59 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='7' Title='3.74 % @ 9/27/2017 1:34:00 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='7' Title='3.74 % @ 9/27/2017 1:39:00 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='5' Title='3.26 % @ 9/27/2017 1:43:59 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='7' Title='3.66 % @ 9/27/2017 1:48:59 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='7' Title='3.66 % @ 9/27/2017 1:54:00 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='12' Title='4.87 % @ 9/27/2017 1:58:59 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='8' Title='3.82 % @ 9/27/2017 2:03:59 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='7' Title='3.69 % @ 9/27/2017 2:08:59 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='10' Title='4.45 % @ 9/27/2017 2:14:00 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='7' Title='3.60 % @ 9/27/2017 2:19:00 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='14' Title='5.30 % @ 9/27/2017 2:24:00 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='8' Title='4.02 % @ 9/27/2017 2:28:59 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='7' Title='3.78 % @ 9/27/2017 2:34:01 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='9' Title='4.23 % @ 9/27/2017 2:39:00 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='10' Title='4.35 % @ 9/27/2017 2:44:00 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='9' Title='4.19 % @ 9/27/2017 2:48:59 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='9' Title='4.13 % @ 9/27/2017 2:54:00 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='8' Title='4.02 % @ 9/27/2017 2:58:59 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='10' Title='4.30 % @ 9/27/2017 3:03:59 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='10' Title='4.45 % @ 9/27/2017 3:08:59 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='15' Title='5.70 % @ 9/27/2017 3:14:01 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='5' Title='3.27 % @ 9/27/2017 3:19:00 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='6' Title='3.45 % @ 9/27/2017 3:24:00 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='5' Title='3.24 % @ 9/27/2017 3:28:59 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='7' Title='3.81 % @ 9/27/2017 3:34:01 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='7' Title='3.66 % @ 9/27/2017 3:39:00 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='7' Title='3.75 % @ 9/27/2017 3:44:00 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='7' Title='3.72 % @ 9/27/2017 3:48:59 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='13' Title='5.17 % @ 9/27/2017 3:54:00 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='15' Title='5.73 % @ 9/27/2017 3:59:01 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='23' Title='7.55 % @ 9/27/2017 4:04:01 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='30' Title='9.10 % @ 9/27/2017 4:09:01 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='13' Title='5.13 % @ 9/27/2017 4:14:29 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='9' Title='4.22 % @ 9/27/2017 4:19:08 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='12' Title='4.94 % @ 9/27/2017 4:24:03 PM'><img src='/images/devices/jon00/perfmon/white.gif' border='0' width='1' height='11' Title='4.67 % @ 9/27/2017 4:29:12 PM'></td><td style='width: 100%'>&nbsp;4.67&nbsp;%</tr></td></table><table border='0' cellspacing='0' cellpadding='0'><tr><td>Low: 2.89 High: 9.10 Av: 4.61 <Values 3.92,3.79,4.26,3.44,3.58,3.32,3.03,3.19,3.19,3.34,4.18,3.54, 3.41,3.24,3.22,3.46,3.90,2.89,3.57,4.41,3.51,4.07,3.51,3.85, 3.42,4.28,3.51,3.01,3.54,3.48,3.60,3.72,3.79,3.28,3.38,3.40, 3.36,3.29,3.95,4.00,3.95,3.61,3.65,3.72,3.50,3.12,3.51,3.10, 3.74,5.41,4.00,3.64,3.46,3.64,3.23,3.90,3.88,3.24,4.02,3.85, 4.96,4.50,3.37,3.87,5.66,3.27,3.70,5.10,5.19,3.71,3.48,4.95, 3.23,3.67,4.22,4.62,5.15,3.21,3.70,3.88,3.62,3.91,3.16,3.60, 4.66,6.46,5.35,5.54,6.32,7.91,4.45,4.41,3.35,3.20,3.29,4.21, 4.25,3.21,3.87,4.16,3.71,5.05,4.22,7.40,3.41,3.65,3.40,4.12, 4.35,4.86,5.30,4.91,4.17,3.80,3.74,3.74,3.26,3.66,3.66,4.87, 3.82,3.69,4.45,3.60,5.30,4.02,3.78,4.23,4.35,4.19,4.13,4.02, 4.30,4.45,5.70,3.27,3.45,3.24,3.81,3.66,3.75,3.72,5.17,5.73, 7.55,9.10,5.13,4.22,4.94,4.67></Values><DateTime 9;27;2017 4:04:00 AM,9;27;2017 4:08:59 AM,9;27;2017 4:14:00 AM,9;27;2017 4:19:00 AM,9;27;2017 4:23:59 AM,9;27;2017 4:28:59 AM,9;27;2017 4:34:00 AM,9;27;2017 4:38:59 AM,9;27;2017 4:43:59 AM,9;27;2017 4:49:00 AM,9;27;2017 4:54:00 AM,9;27;2017 4:58:59 AM,9;27;2017 5:03:59 AM,9;27;2017 5:08:59 AM,9;27;2017 5:13:59 AM,9;27;2017 5:18:59 AM,9;27;2017 5:23:59 AM,9;27;2017 5:28:59 AM,9;27;2017 5:34:00 AM,9;27;2017 5:39:00 AM,9;27;2017 5:43:59 AM,9;27;2017 5:49:01 AM,9;27;2017 5:54:00 AM,9;27;2017 5:58:59 AM,9;27;2017 6:03:59 AM,9;27;2017 6:08:59 AM,9;27;2017 6:13:59 AM,9;27;2017 6:18:59 AM,9;27;2017 6:23:59 AM,9;27;2017 6:28:59 AM,9;27;2017 6:34:00 AM,9;27;2017 6:39:00 AM,9;27;2017 6:44:00 AM,9;27;2017 6:48:59 AM,9;27;2017 6:53:59 AM,9;27;2017 6:58:59 AM,9;27;2017 7:03:58 AM,9;27;2017 7:09:00 AM,9;27;2017 7:14:00 AM,9;27;2017 7:18:59 AM,9;27;2017 7:24:00 AM,9;27;2017 7:28:59 AM,9;27;2017 7:34:00 AM,9;27;2017 7:38:59 AM,9;27;2017 7:43:59 AM,9;27;2017 7:48:59 AM,9;27;2017 7:53:59 AM,9;27;2017 7:58:59 AM,9;27;2017 8:03:59 AM,9;27;2017 8:09:00 AM,9;27;2017 8:14:00 AM,9;27;2017 8:19:00 AM,9;27;2017 8:23:59 AM,9;27;2017 8:28:59 AM,9;27;2017 8:34:00 AM,9;27;2017 8:38:59 AM,9;27;2017 8:43:59 AM,9;27;2017 8:48:59 AM,9;27;2017 8:53:59 AM,9;27;2017 8:59:00 AM,9;27;2017 9:04:01 AM,9;27;2017 9:09:00 AM,9;27;2017 9:14:00 AM,9;27;2017 9:18:59 AM,9;27;2017 9:24:00 AM,9;27;2017 9:28:59 AM,9;27;2017 9:34:00 AM,9;27;2017 9:39:00 AM,9;27;2017 9:44:00 AM,9;27;2017 9:48:59 AM,9;27;2017 9:53:59 AM,9;27;2017 9:59:01 AM,9;27;2017 10:03:59 AM,9;27;2017 10:08:59 AM,9;27;2017 10:13:59 AM,9;27;2017 10:19:00 AM,9;27;2017 10:24:00 AM,9;27;2017 10:28:59 AM,9;27;2017 10:34:00 AM,9;27;2017 10:39:00 AM,9;27;2017 10:44:00 AM,9;27;2017 10:49:00 AM,9;27;2017 10:54:00 AM,9;27;2017 10:58:59 AM,9;27;2017 11:03:59 AM,9;27;2017 11:09:00 AM,9;27;2017 11:14:00 AM,9;27;2017 11:19:00 AM,9;27;2017 11:24:00 AM,9;27;2017 11:29:01 AM,9;27;2017 11:34:01 AM,9;27;2017 11:39:00 AM,9;27;2017 11:43:59 AM,9;27;2017 11:48:59 AM,9;27;2017 11:53:59 AM,9;27;2017 11:58:59 AM,9;27;2017 12:04:00 PM,9;27;2017 12:08:59 PM,9;27;2017 12:14:00 PM,9;27;2017 12:19:00 PM,9;27;2017 12:24:00 PM,9;27;2017 12:29:00 PM,9;27;2017 12:34:00 PM,9;27;2017 12:39:01 PM,9;27;2017 12:43:59 PM,9;27;2017 12:48:59 PM,9;27;2017 12:53:59 PM,9;27;2017 12:59:00 PM,9;27;2017 1:03:59 PM,9;27;2017 1:09:00 PM,9;27;2017 1:14:00 PM,9;27;2017 1:19:00 PM,9;27;2017 1:23:59 PM,9;27;2017 1:28:59 PM,9;27;2017 1:34:00 PM,9;27;2017 1:39:00 PM,9;27;2017 1:43:59 PM,9;27;2017 1:48:59 PM,9;27;2017 1:54:00 PM,9;27;2017 1:58:59 PM,9;27;2017 2:03:59 PM,9;27;2017 2:08:59 PM,9;27;2017 2:14:00 PM,9;27;2017 2:19:00 PM,9;27;2017 2:24:00 PM,9;27;2017 2:28:59 PM,9;27;2017 2:34:01 PM,9;27;2017 2:39:00 PM,9;27;2017 2:44:00 PM,9;27;2017 2:48:59 PM,9;27;2017 2:54:00 PM,9;27;2017 2:58:59 PM,9;27;2017 3:03:59 PM,9;27;2017 3:08:59 PM,9;27;2017 3:14:01 PM,9;27;2017 3:19:00 PM,9;27;2017 3:24:00 PM,9;27;2017 3:28:59 PM,9;27;2017 3:34:01 PM,9;27;2017 3:39:00 PM,9;27;2017 3:44:00 PM,9;27;2017 3:48:59 PM,9;27;2017 3:54:00 PM,9;27;2017 3:59:01 PM,9;27;2017 4:04:01 PM,9;27;2017 4:09:01 PM,9;27;2017 4:14:29 PM,9;27;2017 4:19:08 PM,9;27;2017 4:24:03 PM,9;27;2017 4:29:12 PM></DateTime><Extra ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,></Extra></td></tr></table>
                • #38
                  I just tried to connect remotely with a Fire tablet (Android) and an iPhone and it worked just fine on both. The iPhone is on Sprint as is my Galaxy 6s.
                  So this seems to point to the Galaxy 6s as the problem.
                  Are you aware of anyone using a Samsung Galaxy phone successfully? Maybe it's some setting on the phone that is causing the problem.
                  • #39
                    I'm using a Samsung Galaxy 3 with no problem.
                    Have you tried to restart from scratch? Delete the app, reinstall it, recreate the system.
                    • #40
                      SOLVED!!!
                      YES, That was it!
                      I uninstalled the Imperihome app in the phone (both the lite and Pro version) and then re-installed them and imported the system.
                      It's working perfectly in remote and local now.
                      Thanks for creating this plug-in. It's a lot easier and faster to work with than HSTouch. I hope it keeps working through all of the Android and HS3 updates.
                      Thanks for all the help in solving this.
                      • #41
                        iPad
                        I'm using an iPad without success
                        I've followed the steps outlined above. I'm trying to figure out what I'm missing
                        Devoir
                        • #42
                          I tested
                          https://connected2.homeseer.com/issapi/system ?
                          It returned
                          {"id":"HS3 FOUR","apiversion":1}
                          HS3 v .318
                          Hs3 API v 3.0.0.25
                          IPad v 3.0.8
                          Devoir
