Missing ON/OFF & Dimmer devices
  • Missing ON/OFF & Dimmer devices
    Hi,
    I've just installed this trial plugin and have some security sensors appearing in the IH app. However I can't see any ON/OFF/Dim devices, it says this plugin should scan and find them automatically, any idea why they may not be appearing?
    Here is the settings toolbar for the plugin, ON/OFF, Dimmers etc tabs, as seen in the user guide https://forums.homeseer.com/showthre...29#post1230129
    Cheers
    sensors you have to add by hand. for the on/off devices, did you click on cache rebuild?
      Thanks for the reply, I've no button to "cache rebuild" ?
        what version do you have? I think I have the beta version running, 3.0.0.20
          I'm running 3.0.0.9 trial which was downloaded via the HS Plugin Manager.
          How do I get the latest version, the plugin manager is showing N/A in updates column.
            go to
            plugins
            manage
            disable your current imperihome
            click update listing
            click the arrow next to additional interfaces
            scroll down to beta - click arrow
            put check into imperihome
            install the new version
              Followed those steps, plugin is still not listed in beta section.
                did you update the listing?... it shows up for me.
                are you running windows or linux?
                  Found the issue, had a file called updater_override.txt in my HS folder, deleted it, did a refresh and it's now showing v3.0.0.20 which I've stalled and running
                  Thanks for the help!
