In the plugin thermostat tab I see my thermostat listed and checked. On the app it does not appear anywhere. In debugging the issue i changed the "room" of the the thermostat. In the plugin config screen it still shows up in the "old" room. How do I clear this out and start over? Seems the plugin is confused.
IH does not see Go Control Thermostat
Clues from the log - what does this mean?
Aug-26 8:24:49 AM ImperiHome DEBUG End building cache Aug-26 8:24:49 AM ImperiHome ERROR System.NullReferenceException: Object reference not set to an instance of an object. at HSPI_ImperiHome.ISSDeviceThermostat.FromDevice(DeviceClass dev) at HSPI_ImperiHome.ISSDeviceObject.FromDevice(DeviceClass dev) at HSPI_ImperiHome.ISSCache.BuildListOfAutoGenDevices() Aug-26 8:24:48 AM ImperiHome DEBUG Start building cache
I just fixed one problem in version 3.0.0.23 available from beta section of the updater, please test it and let me know if you still have error in the logs.
thanksPlugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
My blog: http://www.domogeek.ca/blog/
Thanks - I loaded that update and it now shows one thermostat related device in the app - under actuator. It just has the current mode. No ability to adjust temperature, etc.
The config still shows the thermostat in the old room. I have moved it do a new room and it doesn't seem to be picking it up.
I do not see the errors in the log....
do you see your thermostat in the Thermostats tab in the config page of the plugin?
for the room problem, you need to do a "reload" from the IH app, restarting the app is not enough.Plugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
In the config page of the plugin I see the thermostat, but it is in the old room - that is the place it does not seem to pick up the new room. I have rebuilt multiple times with no change. It just doesn't seem to pick up on the fact that the thermostat has changed. Is there a way to manually delete that once item and perhaps force it to look again?
I performed a reload on the app many times, right now it still only has the one actuator device.
Originally posted by grahamk View PostIn the config page of the plugin I see the thermostat, but it is in the old room - that is the place it does not seem to pick up the new room. I have rebuilt multiple times with no change. It just doesn't seem to pick up on the fact that the thermostat has changed. Is there a way to manually delete that once item and perhaps force it to look again?
Could you post some screenshots of where you see your thermostat in the config page, as well as the homeseer devices representing it?Plugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
