Status changeing/not updating on IH dashboard
  • #61
    We made some event changes, can you try build 398 and see if there is any change:
    http://homeseer.com/updates3/SetupHS3_3_0_0_398.msi
    Originally posted by peterpc View Post
    When lights go on very slow, I noticed the following:
    I have an event that will trigger on motion and a virtual device to show the status of the lights.
    It runs when light status is off and switches on the light and set the virtual device to on.
    In the log I see this:
    Dec-16 16:36:45 Device Control Device: Eerste_verdieping: Hobbykamer Licht status to On (100)
    Dec-16 16:36:40 Device Control Device: Eerste_verdieping: Hobbykamer Licht status to On (100)
    Dec-16 16:36:35 Device Control Device: Eerste_verdieping: Hobbykamer Licht status to On (100)
    Dec-16 16:36:30 Device Control Device: Eerste_verdieping: Hobbykamer Licht status to On (100)
    Dec-16 16:36:25 Device Control Device: Eerste_verdieping: Hobbykamer Licht status to On (100)
    Dec-16 16:36:20 Device Control Device: Eerste_verdieping: Hobbykamer Licht status to On (100)
    Dec-16 16:36:15 Device Control Device: Eerste_verdieping: Hobbykamer Licht status to On (100)
    Dec-16 16:36:14 Device Control Device: Eerste_verdieping: Hobbykamer Licht status to On (100)
    Multiple device controls to set the status on, but the event should only trigger once to set the status on.
    I have attached the event.
    When I trigger the event again by switching of the status device, the status device triggers only once.
    I think that will explain that sometimes the lights go on within one second and sometimes it takes 10 to 15 seconds.
    I even have noticed that a light goes on, off again and on again because the event to switch off the light was triggered right after the event to turn on the lights.
    Hope this helps to find the delay problem.
    • #62
      Still a problem:
      Dec-16 18:32:33 NO ECHO No Echo for Slaapkamer Slaapkamer, Echo (3 secs)
      Dec-16 18:32:31 ECHO Echo for Slaapkamer Slaapkamer, No Echo (1 secs)
      Dec-16 18:32:29 NO ECHO No Echo for Slaapkamer Slaapkamer, Echo (3 secs)
      Dec-16 18:32:27 ECHO Echo for Slaapkamer Slaapkamer, No Echo (8 secs)
      Dec-16 18:32:27 Device Control Device: Eerste_verdieping: Slaapkamer Licht status to On (100)
      Dec-16 18:32:27 Device Control Device: Insteon Slaapkamer spiegel(I) to Dim 99% (99)
      Dec-16 18:32:27 Event Event Trigger "Slaapkamer beweging licht aan en tv is uit"
      Dec-16 18:32:17 NO ECHO No Echo for Slaapkamer Slaapkamer, Echo (3 secs)
      Dec-16 18:32:15 Device Control Device: Eerste_verdieping: Slaapkamer Licht status to On (100)
      Dec-16 18:32:15 Device Control Device: Insteon Slaapkamer spiegel(I) to Dim 99% (99)
      Dec-16 18:32:15 Event Event Trigger "Slaapkamer beweging licht aan en tv is uit"
      Dec-16 18:32:15 ECHO Echo for Slaapkamer Slaapkamer, No Echo (14 secs)
      Dec-16 18:32:00 NO ECHO No Echo for Slaapkamer Slaapkamer, Echo (3 secs)
      Dec-16 18:31:58 ECHO Echo for Slaapkamer Slaapkamer, No Echo (5 secs)
      Dec-16 18:31:58 Device Control Device: Eerste_verdieping: Slaapkamer Licht status to On (100)
      Dec-16 18:31:58 Device Control Device: Insteon Slaapkamer spiegel(I) to Dim 99% (99)
      Dec-16 18:31:58 Event Event Trigger "Slaapkamer beweging licht aan en tv is uit"
      Dec-16 18:31:52 NO ECHO No Echo for Slaapkamer Slaapkamer, Echo (1 secs)
      Dec-16 18:31:52 ACTIVE ZONE Slaapkamer Slaapkamer bezet has changed to Active Zone On, Active Zone Off (2 mins, 3 secs)
      Dec-16 18:31:51 ECHO Echo for Slaapkamer Slaapkamer, No Echo (4 mins, 3 secs)
      Dec-16 18:31:51 Device Control Device: Eerste_verdieping: Slaapkamer Licht status to On (100)
      Dec-16 18:31:51 Device Control Device: Insteon Slaapkamer spiegel(I) to Dim 99% (99)
      Dec-16 18:31:51 Event Event Trigger "Slaapkamer beweging licht aan en tv is uit"
      Peter
      http://ohh.pcgsm.nl
      • #63
        Today I entered my office and light went on immediately like it should, but then go off and on again.
        This is the log:
        Dec-17 15:40:51 NO ECHO No Echo for Hobbykamer Hobbykamer, Echo (1 secs)
        Dec-17 15:40:51 ECHO Echo for Hobbykamer Hobbykamer, No Echo (1 secs)
        Dec-17 15:40:48 NO ECHO No Echo for Hobbykamer Hobbykamer, Echo (0 secs)
        Dec-17 15:40:48 NO ECHO No Echo for Voorkamer Voorkamer, Echo (4 secs)
        Dec-17 15:40:48 Device Control Device: Eerste_verdieping: Hobbykamer Licht status to On (100)
        Dec-17 15:40:48 Device Control Device: AAA_test Hobbykamer Plafond(I) to Dim 80% (80)
        Dec-17 15:40:48 Event Event Trigger "Hobbykamer hobbykamer Licht aan"
        Dec-17 15:40:48 ECHO Echo for Hobbykamer Hobbykamer, No Echo (0 secs)
        Dec-17 15:40:47 NO ECHO No Echo for Hobbykamer Hobbykamer, Echo (0 secs)
        Dec-17 15:40:47 ECHO Echo for Hobbykamer Hobbykamer, No Echo (0 secs)
        Dec-17 15:40:46 NO ECHO No Echo for Hobbykamer Hobbykamer, Echo (1 secs)
        Dec-17 15:40:46 ACTIVE ZONE Hobbykamer Hobbykamer bezet has changed to Active Zone On, Active Zone Off (38 mins, 9 secs)
        Dec-17 15:40:45 ECHO Echo for Hobbykamer Hobbykamer, No Echo (40 mins, 11 secs)
        Dec-17 15:40:44 ECHO Echo for Voorkamer Voorkamer, No Echo (8 secs)
        Dec-17 15:40:44 Device Control Device: Eerste_verdieping: Hobbykamer Licht status to Off (0)
        Dec-17 15:40:44 Event Event Trigger "Hobbykamer hobbykamer Licht uit"
        Dec-17 15:40:43 Device Control Device: AAA_test Hobbykamer LED Lamp Module(IE) to Dim 70% (70)
        Dec-17 15:40:43 Event Event Trigger "Hobbykamer led lamp aan"
        Dec-17 15:40:43 Device Control Device: Eerste_verdieping: Hobbykamer Licht status to On (100)
        Dec-17 15:40:43 Device Control Device: AAA_test Hobbykamer Plafond(I) to Dim 80% (80)
        Dec-17 15:40:43 Event Event Trigger "Hobbykamer hobbykamer Licht aan"
        The trigger to start the event (motion) should have been the first in the log because it triggered the event, but event starts first.......
        Peter
        http://ohh.pcgsm.nl
