Imperihome (Android) will not connect to API
  • Imperihome (Android) will not connect to API
    I feel like I'm losing my mind because the connection on this is so simple, but it will not work no matter what I do. I've found some previous threads with similar issues but none of them seem to have run into the same problems I have. I'm sure I'm missing something ridiculous.
    I have custom http server enabled, using port 8072, and i'm using Local API Base URL http://IPADDRESS:8072/issapi
    I have not entered a username or password.
    I am running HS3 Pro 3.0.0.435 on Linux.
    Port 8072 is open and listening on my Linux box.
    When I restart the plugin, I get this error in the logs and nothing else of note:
    Aug-03 12:15:13 AM ImperiHome ERROR System.IO.FileNotFoundException: Could not load file or assembly or one of its dependencies. File name: 'System.Xml.Linq, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' at Newtonsoft.Json.JsonSerializer.GetMatchingConverter (IList`1 converters, System.Type objectType) <0x40f3d3d0 + 0x00054> in :0 at Newtonsoft.Json.Serialization.DefaultContractResolver.InitializeContract (Newtonsoft.Json.Serialization.JsonContract contract) <0x40f3c740 + 0x00157> in :0 at Newtonsoft.Json.Serialization.DefaultContractResolver.CreateObjectContract (System.Type objectType) <0x40f3ba80 + 0x0006b> in :0 at Newtonsoft.Json.Serialization.DefaultContractResolver.CreateContract (System.Type objectType) <0x40f35e30 + 0x0028f> in :0 at Newtonsoft.Json.Serialization.DefaultContractResolver.ResolveContract (System.Type type) <0x40f35ac0 + 0x00144> in :0 at Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.GetContractSafe (System.Object value) <0x40f35a70 + 0x00042> in :0 at Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.Serialize (Newtonsoft.Json.JsonWriter jsonWriter, System.Object value, System.Type objectType) <0x40f357b0 + 0x000e7> in :0 at Newtonsoft.Json.JsonSerializer.SerializeInternal (Newtonsoft.Json.JsonWriter jsonWriter, System.Object value, System.Type objectType) <0x40f34d00 + 0x005df> in :0 at Newtonsoft.Json.JsonSerializer.Serialize (Newtonsoft.Json.JsonWriter jsonWriter, System.Object value, System.Type objectType) <0x40f34cd0 + 0x00020> in :0 at Newtonsoft.Json.JsonConvert.SerializeObjectInternal (System.Object value, System.Type type, Newtonsoft.Json.JsonSerializer jsonSerializer) <0x40f305e0 + 0x00113> in :0 at Newtonsoft.Json.JsonConvert.SerializeObject (System.Object value, System.Type type, Newtonsoft.Json.JsonSerializerSettings settings) <0x40f2efd0 + 0x0002f> in :0 at Newtonsoft.Json.JsonConvert.SerializeObject (System.Object value) <0x40f2eef0 + 0x00013> in :0 at HSPI_ImperiHome.ISSServer.HandleRequest (System.String absolutePath) <0x40f2e8d0 + 0x000cb> in :0
    Aug-03 12:15:13 AM ImperiHome TRACE ISSServer Request: /issapi/system
    Aug-03 12:15:08 AM ImperiHome ERROR System.IO.FileNotFoundException: Could not load file or assembly or one of its dependencies. File name: 'System.Xml.Linq, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' at Newtonsoft.Json.JsonSerializer.GetMatchingConverter (IList`1 converters, System.Type objectType) <0x40f3d3d0 + 0x00054> in :0 at Newtonsoft.Json.Serialization.DefaultContractResolver.InitializeContract (Newtonsoft.Json.Serialization.JsonContract contract) <0x40f3c740 + 0x00157> in :0 at Newtonsoft.Json.Serialization.DefaultContractResolver.CreateObjectContract (System.Type objectType) <0x40f3ba80 + 0x0006b> in :0 at Newtonsoft.Json.Serialization.DefaultContractResolver.CreateContract (System.Type objectType) <0x40f35e30 + 0x0028f> in :0 at Newtonsoft.Json.Serialization.DefaultContractResolver.ResolveContract (System.Type type) <0x40f35ac0 + 0x00144> in :0 at Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.GetContractSafe (System.Object value) <0x40f35a70 + 0x00042> in :0 at Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.Serialize (Newtonsoft.Json.JsonWriter jsonWriter, System.Object value, System.Type objectType) <0x40f357b0 + 0x000e7> in :0 at Newtonsoft.Json.JsonSerializer.SerializeInternal (Newtonsoft.Json.JsonWriter jsonWriter, System.Object value, System.Type objectType) <0x40f34d00 + 0x005df> in :0 at Newtonsoft.Json.JsonSerializer.Serialize (Newtonsoft.Json.JsonWriter jsonWriter, System.Object value, System.Type objectType) <0x40f34cd0 + 0x00020> in :0 at Newtonsoft.Json.JsonConvert.SerializeObjectInternal (System.Object value, System.Type type, Newtonsoft.Json.JsonSerializer jsonSerializer) <0x40f305e0 + 0x00113> in :0 at Newtonsoft.Json.JsonConvert.SerializeObject (System.Object value, System.Type type, Newtonsoft.Json.JsonSerializerSettings settings) <0x40f2efd0 + 0x0002f> in :0 at Newtonsoft.Json.JsonConvert.SerializeObject (System.Object value) <0x40f2eef0 + 0x00013> in :0 at HSPI_ImperiHome.ISSServer.HandleRequest (System.String absolutePath) <0x40f2e8d0 + 0x000cb> in :0
    I appreciate any help in advance.
    Is there anyone that has any suggestions on this? Thanks.
      sorry for the delay, the dll System.Xml.Linq.dll is missing on your system.
      if you haven't already done it. install mono-complete package
      sudo apt-get install mono-complete
      or only reinstall the missing package:
      sudo apt-get install libmono-system-xml-linq4.0-cil
