I have a garage door that I want to monitor and control. Here is a kicker - the garage door status is monitored by a simple z-wave magnetic door sensor and shows garage door is open/closed in in Imperihome. I have a z-wave relay that triggers the open/close button and controls the door. I can add another widget to the Imperihome screen to toggle that switch. What I would like to do (if possible) is to use one widget instead of two. I want the same widget that gets the door open/closed status from the door sensor, but when I click on the widget it would trigger the relay on/off state to open or close the door. Is it possible with one widget? Or do I have to use two? Thanks
Status from one device and click action from other - possible?
Hey there..... I do exactly this. you'll need to create a single garage door virtual device that you use in Imperihome for your garage door....
I just got it working again, thanks to Randy in this forum. Should tell you what you need.
https://forums.homeseer.com/forum/ho...help-debugging
