Imperihome Plugin - Multi-Instance?
    I don't quite understand the use of multi-instance config files in the plugin. I am hoping someone can explain their use.
    Here is what I would like to do:
    I use HS3 with the Imperihome plug at my main residence. I also have a vacation cabin where I run an HS Zee V2.with the IH plug.
    I would like to have one instance of IH with devices for the main residence and another instance of IH showing devices for the cabin.
    Following the example in the plugin user guide, I create another instance, "cabin" and enable both.
    How do you then switch between instances?
    And, when it says you must use a different http port for each instance, is it referring to the IH (issa) port? (default = 8072).
    Sincere thanks for any info and clarification on this. I have been trying to wrap my head around this for a couple of days now.
    If you have 2 separate HS3 systems, you don't need the multi instance feature of the plug-in.
    In IH app, just create 2 objects for your 2 HS3 systems, and that's it, you will get devices from both your systems in the device list.
      That makes sense! Perfect Spud. Thanks for the reply.
      Really nice plugin too.
