I have about 10 cameras in Blue iris that I setup through the camera tab in the IH config..... work perfectly on local LAN.
today, I notice that suddenly it says It can stream an image so various and what seem to be random cameras. a bit later they all work again. All seem fine when using the blue iris client.
I don't see anything in the logs, so not even sure where to trouble shoot yet. thought i'd come here first and see if anyone has seen anything strange?
A little more weirdness. I rebuild the logs in the IH plugin. Go to one android device and try to add a new camera widget. under the cameras tab in IH, I see all my cameras, and two widgets for each (still shot and motion).
On a separate android device, I try the same thing, and I see a slightly different list, with only 1 widget for each camera.
and I've reloaded both devices multiple times after rebuilding the IH logs.
