It appears that with the last iOS update that some of the multiswitch functions for devices are not working. This includes a Z-wave water shut off valve, Z-wave Light Bulb, Z-wave garage door opener. All of these were working correctly and reporting status up until the latest update. I love this UI and use it all the time for my second home. Can someone please comment if they are seeing this issue and if the developer is aware of it. Thank you!
Multiswitch NOT working with iOS on latest release on some devices
I noticed that on one of my devices. I switched it to an on/off device for now, but have not noticed if other multi-switch devices are affected. Do you get any errors in the log when trying to use a multi-switch device? This is the message I saw in the log:
ImperiHome ERROR can't find id_open control for device 6370 HS 3.0.0.548: 1990 Devices 1172 Events
I'm getting the same error code:This was working before the software upgrade. Pretty sure it was both an iOS and Plugin update in the last 3 weeks. Looks like a mapping issue from the IH to the device. Something is broken or got wiped out. I have tried to rebuild the cache with no luck. Thanks for any help restoring the function. It is really critical to my deployment.ImperiHome ERROR can't find id_on control for device 412
I have the same issue.
juin-20 07:40:07 Device Control Device: Virtual Status Device Alarm Partition Status to Disarmed (0) by/from: CAPI Control Handler juin-20 07:39:08 ImperiHome ERROR can't find id_disarmed control for device 1392 juin-20 07:38:57 ImperiHome ERROR can't find id_disarmed control for device 1392
thanks
Olivier
I can reproduce the problem with the iOS app version 4.3.4
It's caused by a breaking change or possibly a bug introduced in this version, I'm going to ask the developer for more information and will get back to you with a fix. Thanks.Plugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
My blog: http://www.domogeek.ca/blog/
The developer said it's fixed in the new beta version that can be installed through the TestFlight app. Unfortunately for some reason TestFlight crash on my ipad, so I can't test the beta.
If you want to test by yourself you can register to the beta program here: https://evertygo.typeform.com/to/tF1wkQPlugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
Hello -- thank you for working on resolving this issue. I tried the above link and could not get to where I need to download the App or Redeem the Code to download in TestFlight. is it possibly to post the Beta in the HomeSeer Beta section? Or provide a link where I can generate the Redeem Code. Thanks again, Chris
