Create Volume slider
In HS,
set the "Control Use" field of the slider control to "Dim"
and set the "Control Use" field of the 2 other buttons to "On" and "Off". even if does not make much sense but this is needed for the plugin to recognize the device as a dimmer
then click Cache: Rebuild in the config page. The volume device should then appear as a dimmer device.Plugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
My blog: http://www.domogeek.ca/blog/
- 1 like
thanks Spud!
If so you would need to have one device with both the volume slider, and the mute/unmute controls, because the plugin can only match one dimmer widget in IH to one device in HS.
Do you mean you want the on/off button to mute/umute the audio?
right now, the slide works, but the on/off rocker button does nothing.
Hey... coming back to this after some time.
spud I think it get it. because the Volume is a separate device from Z1Power (standby/on), I can't have power and volume as part of the same IH widget.
The problem is, using your fix above, I get a IH light/dimmer widget where the slider works the volume perfectly... but the on/off button does nothing. If I can't program that to actually map to the on/standby Z1Power device, can I at least have a dimmer widget in IH that has the slider but NOT the on/off button?
You could configure your device as a shutter instead of a dimmer, but I guess you will have the same problem as a shutter needs to map controls for stop, open and close.Plugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
