More frequent logging of chart data ?
  • spud
    Originally posted by Daveyboy View Post
    Thanks Spud - I've added the new line (without the ; ) and will test etc.
    yeah I added the ; by mistake, I fixed the original post.
  • Daveyboy
  • spud
    it's a "point in time" every hour, but you can modify it by adding the following line in ImperiHome.ini in the [SENSORS] section and then restart the plugin:
    [SENSORS]
    polling_interval=3600000
    polling_interval is in milliseconds, so do not set this to a very low value, or the database will become huge quickly.
  • Daveyboy
    started a topic More frequent logging of chart data ?
    Hi Spud,
    Would it please be possible to enable an option to log data and display the resulting graph from a device more often than the 1 hour default ?
    Or perhaps it's a misunderstanding that the data is not a 'point in time' every hour, but a sum of the data collected within that hour ? In which case could you please confirm.
    e.g. Watts are logged on a device, it peaks at 2Kw at 50 minutes but runs at 200w every minute. Would your plugin capture the 200w at the top of the hour, or the sum during the hour, or maybe the peak during the hour ?
    David
