In the past week, I have installed 3 Stelpro thermostats. All three function fine in HS. However, 1 of the 3 does not display temperature in IH. All other functions work correctly (e.g. heat setpoint), just not the temperature (displays 0.0). I can manually add the temperature part of the thermostat as a sensor and that will display the correct temperature.
I have tried reinstalling the plugin and rebuilding the cache, but that didn't fix the issue.
What else can I try?
