I've had Imperihome Premium working fine on two Android phones for over a year. Recently switched to new Pixel 4 phones, and set things up. Still continued to work fine.
Yesterday both phones began failing to update Homeseer via Tasker, using Imperihome. Went into Imperihome and everything is blank.
I've tried:
1) Clearing cache
2) Clearing storage
3) Uninstall/reinstall
4) Re-setting up the connection.
5) Stopping and restarting Imperihome.
6) Rebuilding the Imperihome database.
7) Tried using connected11 instead of connected 2, as I've seen in other threads.
Nothing works.
When trying to set up the connection (I have two homeseer instances in different locations) I receive the "!Error: Invalid response from API" message.
myhs works fine, google assistant can connect, and the Homeseer Mobile and Touch apps all work. Just Imperihome continues to fail.
I've checked the Public/Private network on the HS server (Win 10 pro) and since I'm using a wired ethernet connection, it's set to Private. I've turned off Windows Firewall (which had been working fine for over a year) and no results.
What could be wrong? The other thread that lists a similar problem had no resolution, just a mysterious (it works now), and the connected11 trick worked there. It doesn't work here.
I've tried:
1) Clearing cache
2) Clearing storage
Nothing works.
