Greetings,
With the help of this forum I was able to make a switch which controlls a garagedoor and updates the status.
https://forums.homeseer.com/forum/ho...ng-it-s-status
This is the virtual switch with the added status:
What happends:
-I press the controll open: an events toggles the actual garage door, the status part of that switch changes to 1 (stuck or transit) , after 15 seconds the garagedoor is checked with sensors what the actual status is ( open -close or transit) and than changes the status to the actual status , hopefully in this example "2".
-When I press controll close: the same happends, just the oposite.
This works fine in the HS Gui, but I use Imperihome ( for how long it still lasts) . The Virtual switch does not show up in the on/off devices , probably since it has also the status integrated. Anyone has an idea how to tackle this problem? Maybe fool the plugin as an RGB-light or as shutter, since when I set for example on one of my shade- shutters a value with the slide, since the physicall device is slow it shows the actual status on the Imperihome Gui graphics.
Or is there a better way?
Many thanks,
Cor
What happends:
Many thanks,
Cor
