Great. I also noticed when editing the sensor fields, whatever text is already in the field, does not appear in the popup used for editing the text.
Al
This happens because when you add or change something in the sensors tab, the plugin only does a partial refresh of the page. I'll try to see if this can be fixed, but I doubt it. The workaround is to force a full refresh by hitting F5.
Thanks, I will do that for now. Any thoughts on the issue I posted in post #55?
Al
HS 3.0.0.548: 1976 Devices 1156 Events
Z-Wave 3.0.1.262: 123 Nodes on one Z-Net
Thanks Spud. I appreciate your responsiveness for your plugins.
All working well and looks like your enhancements in the works will make this quite a useful little tool.
I edited my original post EDIT: SOLVED
Can't access through Imperihome setup OR another Ipad
Firewall is off. (Didn't realize my computer was set with 3 layers of firewalls)
Jim
Plugins:Z Wave 3.0.1.55, HS3 Pro 3.0.0.208, HS3Touch, HS3Touch IOS, Z-Net, SceneMaster, XBMC, Sonos, Media Controller, Envisalink (52 Virtual nodes), JowiHue, EasyTrigger, Liftmaster MyQ, BLBackup, BLLAN, BLRadar, Pushover
Devices:Cooper RF9540, Cooper Scene, Yale Locks, Sonos, Phillips Hue and Lux, DSC, Somfy Blinds
When deleting devices in HS, I get the following entries in the log:
ImperiHome ERROR System.NullReferenceException: Object reference not set to an instance of an object. at HSPI_ImperiHome.ISSCache.RemoveDevice(Int32 dvRef)
Al
