MyQ Garage Door Control with ImperiHome
  • #31
    <update>
    MyQ plugin update is now working for me BUT status is not correct... the default on/off (red/green) switch always shows ON and garage icon (garage door open/closed) always shows the door open
    I deleted the devices and let the MyQ rebuild them... and added and re-added to IH.
    any ideas?
    • #32
      Originally posted by Ltek View Post
      <update>
      any ideas?
      I can't tell that Eric made the fundamental change needed for this to work. The Status and Control must use the same values (numeric) for Open and Close. Opened Status is 1, Closed Status is 2, Open Control is 100 and Close Control is 200.
      The Status and Control values must be the same to follow iH conventions. Eric would have to answer this, but I don't see any reason why Open Control and Opened Status can't be 1 with Close and Closed being 2. Numeric values are arbitrarily set by the plug-in and there is no reason why a Control value and a Status value can't be the same, even when they are separately declared.
      You can even use different Status and Control text using the same values.
      Since the device is owned by the MyQ plug-in, the author will have to change the values, you cannot edit the device without breaking the plug-in.
      Randy Prade
      Aurora, CO
      Prades.net
      • #33
        Good catch, forgot to change the values along with the control use. I'll get it in the next update
        • #34
          I meant to send you an email, but time got away from me. As you probably know, you can change everything to be 100, 200, 300, 400 or 1, 2, 3, 4.
          Randy Prade
          Aurora, CO
          Prades.net
          • #35
            as of the .94 release it should work.
            • #36
              The new version is installed and working well. After deleting the old device a new one was created with status and control values the same. It should now work properly with the IH plug-in.
              Randy Prade
              Aurora, CO
              Prades.net
