Update ImperiHome of Homeseer changes
    ImperiHome is simply marvelous.
    However Ihave a serious problem. My homeseer changes is not reflected in the ImperiHome app. How does I update it?
    I did not help to dis/enable the ImperiHome plugin
    Hit the reload option in the settings gear in the ImperiHome app.
    cheeryfool
      Thanks (Solved)
      That worked
        I do not have a setting gear, but three dots and no option under settings to reload.
        HomeSeer 3 V 3.0.0.318 with ALEXA (AKA Amazon Echo)
        BL Radar V2.0.217; BLRF V2.0.85.0; HS Touch V3.0.0.1034 X10 V3.0.0.42; PHLocation V3.0.0.38; Zwave V3.0.1.110; X10 V3.0.0.42
        BLBackup V2.0.39;ImperiHome3.0.0.20 All on Windows XP Pro
          In the iOS app (current version) AND in the Dashboard view, there's a settings cog top right. This is not the same as the app settings from the main menu.
          I am guessing you have the android version perhaps if it's slightly different
          cheeryfool
            I'm on android and in both the dashboard view and the list view, the three dot menu has the option "reload"
              The three dots give me an option for settings and About, neither give me reload on an android. it is there on my laptop which is running an emulator
                The Reload button in the app only works for me if I have already restarted HS3. The only way I have ever been able to get ImperiHome to update is to either disable then re-enable the plugin for ImperiHome in HS3, or just rebooting the system/quitting and restarting HS3. THEN you have to press Reload in the app, but just pressing it never updates anything for me unless HS3 or the plugin have restarted. Has always been like that for me.
                  I used to have this same issue when trying to run ImperiHome on the Wink Relay but it was because that device was running an old version of Android which for some reason would cause menu items to disappear in ImperiHome. For me it was the whole 3 dots missing though.
