I have devices with the value being stored as a whole number and using the VSPair RangeStatusDecimals to specify the number of decimal points (i.e. the value is divided by RangeStatusDecimal before being displayed in HS3/HSTouch).
When the same values are displayed as Temperature sensors in ImperiHome, it does not honor the RangeStatusDecimalssetting and displays the value without transformation (I assume the same applies for other factores you can specify in VSPair).
If I map it to a generic sensor checking the string status, it is displayed as expected, though the default icon is not as desired and more importantly the values in the chart when enabled are not correct.
Could this be corrected in a future version? Thanks
