Album art squeezebox on HS hard drive
  • Album art squeezebox on HS hard drive
    Is there a way to show images from the hard drive (HS server) as a camera snapshot?
    I use the SqueezeBox plugin and this plugin generates for every squeezebox two images that I want to display in IH.
    The files are located in the html dir of HS, for my living room squeezebox like;
    C:\Program Files (x86)\HomeSeer HS3\html\SqueezeBox\AlbumArtwork_Squeezebox Woonkamer_1.current.jpg
    C:\Program Files (x86)\HomeSeer HS3\html\SqueezeBox\Squeezebox Woonkamer_1.current.jpg
    Any help is appreciated.
    Yes, I do the same. Just use the URL to the file:
    http://www.xxx.yyy.zzz/SqueezeBox/AlbumArtwork_SqueezeboxWoonkamer_1.current.jpg
    Change the www.xxxx.yyy.zzz to the ip address of your homeseer server.
    Cheers
    Al
    HS 3.0.0.532: 1963 Devices 1141 Events
    Z-Wave 3.0.1.261: 122 Nodes on one Z-Net
      Hi Al,
      Thnx for your fast response.
      Unfortunately it shows only a camera picture in IH, so I am missing something.
      Any ideas?
        Originally posted by Broes View Post
        Hi Al,
        Any ideas?
        What happens when you paste that URL in a browser? It should bring the image up as well.
        Cheers
        Al
          Then I get the message that the other side (www.xxxx.yyy.zzz) refused the connection.
            Do you run HomeSeer's web server on a non-standard port? Something other than port 80? If so, add :aa after the .zzz in the example so http://www.xxx.yyy.zzz:aa/ and change aa to the port number you are using.
              Yes, port 86
              But no luck with adding this port number, I get a "404 bad request" back.
                If there are any spaces in the filename, replace those with %20
                Looking at your original post and my original reply, it looks like I might have dropped a space.
                  Progress!
                  Indeed a missing space.
                  Both pictures show up in my browser
                  So I will play around with IH to see if I can get further from here.
                  I will let you know.
                  Edit: Working!
                  On my phone I've got the pictures, so I have to find out why I am not getting the "Live Camera Widget" option on my tablet.
                  Edit2: after restarting my tablet it is working too.
                  I am a happy man now, thanks very much!
