IMPORTANT - UPGRADE PROCEDURE FROM 1.0.x:
Description:
InControl For Windows Phone 7 includes HomeSeer 2.0 and Windows Phone 7 plugins that work together to provides a real-time, interactive interface between your Microsoft Windows Phone 7 and Homeseer. With InControl, you are provided with an easy to use, graphical interface in Windows Phone 7 to control and monitor any HomeSeer devices no matter where you are.
Features:
Requirements:
Installation:
More Information:
Feeback:
Version Information:
1.2.0
- Close HomeSeer (server/service) and do a backup of the entire HomeSeer directory, should you need to return to the pervious verison.
- Access HomeSeer Updater and download/isntall InControl version 1.3.1.
Description:
Features:
- Control and/or monitor any Thermostats in HomeSeer from Windows Phone 7
- Control and/or monitor any device in HomeSeer from Windows Phone 7
- Start any Event in HomeSeer from Windows Phone 7
- Secure connection via HomeSeer user id and password
- Custom graphic library included for Windows Phone 7
Requirements:
- Windows Phone 7 or higher
- InControl For WP7 App (available MarketPlace)
- HomeSeer 2.0 or higher
- InControl For HomeSeer Plugin (available through HomeSeer store and updater)
Installation:
- Be sure to download and install the InControl Plugin for HomeSeer first. It is available through the HomeSeer Updater and Store.
- Once InControl is running on your HomeSeer server, you can download and install the InControl Windows Phone 7 App from the Microsoft MarketPlace.
More Information:
Feeback:
- Enhancment Requests - There are many other features I am planning to add to this plugin. However, please feel free to post any enhancment ideas and I will do my best to add the capability.
- Defect Reports - Please post any bugs or issues in this forum.
1.2.0
New Features:
- Added support for thermostats. There are two types of thermostats that can bee added. (1) Thermostats Supporting the HomeSeer Thermostat API - this will automatically determine the thermostat capability and be pre configured. (2) Custom Thermostats (do not support HomeSeer Thermostat API) - this will require custom interfaces using Scripts to the thermostat.
- Added capability to customize and send any device control buttons to the client
- Changed send methed to use threads to avoid delay between events
- Fixed issue with configuration settings being saved in settings.ini instead of hspi_incontrol.ini
- HTML being sent as Device Strings was causing issues, added logic to strip out HTML
- Fixed event not being sent properly when activated by client causing event not to trigger
