Installing error: Knocks out the sageTV error
  • Installing error: Knocks out the sageTV error
    I've tried multiple times. Each time install this WP7 plugin, the SageTV plugin is removed. It does not show up in the Interfaces list and it's even gone from "Add/Remove programs"...
    Last edited by Moskus; March 7th, 2012, 12:49 PM. Reason: It doesn't knock out the "sagetv error", but the "sagetv plugin"...
    .... hello?
      Moskus,
      Thanks. There are a few ways to approach this, can you let me know the following?
      What version of the Sage TV Plugin are you using?
      What version of the WP7 Pluging are you using?
      Would you want the same devices available on Sage to be available on WP7 (I assume so from your other post, but please verify).
        Originally posted by lamanmi View Post
        Moskus,
        I'm using the latest SageTV plugin from the updater (1.4.7.0). And I'm trying to install the latest WP7 plugin from the updater.
        When I do that, I restart HomeSeer and see that the SageTV plugin is gone and replaced by the WP7 plugin. To get it back I have to shut down HS, remove WP7 plugin and the SageTV plugin from the "Add and Remove programs" (in Control Panel), and reinstall the SageTV plugin.
        I really want all to be available in the SageTV (and WP7) plugin. I have my devices neatly sorted using Locations 1 and 2, and as long as they are visible I'd like to be able to view and control them from SageTV and WP7.
        Having to select each device I want to control is somewhat limiting. And it's a rather boring job to select them...
