Event Trigger - Phone Location
  • Event Trigger - Phone Location
    I want to be able to trigger an event when InControl Phone Location Device value changes. Unfortunately that device is only setup to update the device string (43.915,-72.378) and not value.
    Is there a way to have an event trigger based on the device string changing or can you please modify the plug-in to set the device value based on the phone location changing?
    For example, if phone location changes, toggle device value so HS sees that the phone location has changed and an event can trigger.
